Parking light stays on
Old Oct 24, 2018 | 04:27 PM
alan8745's Avatar
alan8745 is on a distinguished road
Default Parking light stays on
Ok I have a 2001 chev blazer 4wd 4dr that the brake light stays on! Won’t go out out! Now for the things I’ve tried
reset computer
replaced pads & rotors
calipers are good
abs wheel and senors are good
fluid level at max
no leaks at any of the wheels
checkled and unplugged sensor at fluid res.
no ABS problems or lights or codes
What do I need to do next?
Old Oct 24, 2018 | 04:39 PM
Rusty Nuts's Avatar
Sorry. I've respnded to the wrong thread.
Old Oct 24, 2018 | 05:18 PM
Mike.308's Avatar
When/how does it happen?
Old Oct 24, 2018 | 07:44 PM
I'm a little confused...
You post title says "parking light", then in your post you say "brake light". Then you go as far as mentioning resetting the computer and checking the brake fluid level, which leads me to believe you're referring to the "BRAKE" light in the cluster?
Old Oct 26, 2018 | 12:10 PM
LesMyer's Avatar
Probably the switch on the parking brake that turns on the brake light is being triggered. Wasn't mentioned in the OP's list.
Old Oct 29, 2018 | 09:19 AM
White01blazer's Avatar
White01blazer is on a distinguished road
From what I gather with your information it sounds like a faulty brakelight switch. Usually cheap and easy to replace. However I agree with the question/post being confusing... so my answer may or may not be correct.
Old Oct 29, 2018 | 02:13 PM
jparker7269's Avatar
jparker7269 is on a distinguished road
I have to lift my parking brake slightly with my foot, when released to make the light go off.
Old Oct 29, 2018 | 07:07 PM
2001ZR2's Avatar
The parking brake assembly can be replaced unfortunately I can't find the information for it but I had to replace mine in my ZR2. Or you can just move it with your foot.
Old Oct 30, 2018 | 08:18 AM
alan8745's Avatar
Default Brake switch
ok I do believe it’s the brake switch is not releasing after releasing the brake pedal. So will try that next!
Old Oct 30, 2018 | 08:30 AM
which is it? Parking brake as in emergency brake? Or pedal brake as in what you use to stop?
Amber Kay
Dec 22, 2015 08:46 AM
cleburne red
Oct 18, 2011 07:11 PM
Diablo1982
Aug 18, 2011 11:08 AM
hoosiergc
Aug 22, 2010 01:09 AM
xplorgee
Aug 11, 2005 11:59 AM
