pcm or tranny questions
Old Oct 10, 2017 | 06:29 AM
LesMyer's Avatar
Originally Posted by Graveyard
Do you happen to remember the re-learn procedure?
Different pcm and theft deterrent I think between 1996 and 2001. Also I think 1996 doesn't use a BCM? If it won't start I would ask the seller of the pcm. He did program it for you to your vehicle SN, right (asked for your vin)? Mine came with instructions on a card to reprogram the theft deterrent. Good luck.
p.s. the service that I used was "Flashmasters"
pps I found instructions that cover the theft deterrent programming for various GM systems after replacing the PCM. It tells you how to ID which system you have. Also note that you will need to have a crank sensor relearn done after replacing the PCM in order for the misfire detection to work correctly.
http://my.cardone.com/techdocs/pt%2077-0011.pdf
Old Oct 10, 2017 | 07:08 PM
Graveyard's Avatar
Graveyard is on a distinguished road
I don't have it yet, I was wanting to know what I was getting into first.
Thank you for the information. Very nice.
See ya Les
Old Nov 15, 2017 | 06:50 PM
Graveyard's Avatar
another question, Is the vehicle driveable before the crankshaft position sensor re-learn?
And after the pcm replacement...
I don't suppose Car Gauge Pro or Dash Command has the re-learn option?
Thanks
Old Nov 16, 2017 | 09:12 AM
LesMyer's Avatar
Thanks
Yes, it is perfectly driveable - but expect SES light to be on with the new PCM. Sorry, no crank sensor relearn on the inexpensive software. I do it with HP Tuner's VCM scanner and a laptop. Others report EFI live and Autoenginuity softwares will do it as well. Also as I understand, most Snap on scanners will do crank sensor relearns.
William Albert
Performance & Brainstorming
Jan 13, 2014 12:57 PM
98Ltblazer
May 4, 2010 08:35 PM
nofear17bmx
Jan 14, 2007 12:22 AM
4lowlife
Engine & Internal
13
Jun 14, 2006 03:10 PM
Dory
May 9, 2006 06:12 PM
