Pinpointing Exhaust Noise
Old Jan 26, 2010 | 01:54 PM
sparky672's Avatar
sparky672 is on a distinguished road
Originally Posted by Gimpy Blazer
You should not have any cracks in your manifolds.
I realize that but after 200,000 miles I'm not too shocked. What would cause these small cracks? I never overheated or had a clogged exhaust.
Is there a critical reason why these should be changed other than additional noise?
To find out exactly where your leaks are get about 4 ft of old garden hose (I like the 1/2" variety) and then you can start the truck and put one end up to your ear and probe around with the other. Call it a poor man's stethescope. You can pinpoint where you exhaust is leaking within that 1/2".
I will verify with your method but I'm fairly certain most of the leak/noise is coming from donut area. I do not see any holes or cracks in any of the pipes.
As far as the studs/nuts/springs go Dorman has a kit with all the items in it. I think it's about $6 or $7 but you get it all. When you pull one of the stude you are not supposed to reuse it.
If it's the same as Napa's $5 kit, I think it's just for one stud/spring/nut. But I'll check it out.
You can also try to put some hydrogen peroxide on the rusty nuts. It works pretty good too. I personally like the Amsoil penetrant but it's just personal preference. I just replaced my whole exhaust system on my 94. Didn'y start that way. Just wanted a Cat-back. Then the converter was bad (emissions test) and adter that the crossover (Y) pipe was toast and leaking so.... Good luck. Just have patience.
Those are great tips. Thank-you.
If you have even a propane torch (like a Bernz-O-Matic) you can get up enough heat to heat the manifold stud area and they'll come out easier
I have a propane torch as well as acetylene.
Old Jan 27, 2010 | 11:49 AM
sparky672's Avatar
One more question:
How long do the donut gaskets typically last?
Back in 1999 (128,000 miles) I changed the muffler & tailpipe assembly and disappointedly remember no reduction in exhaust noise. So I'm thinking that was my problem all along. Of course it's gotten worse since then.
Old Jan 28, 2010 | 01:21 AM
Gimpy Blazer's Avatar
Gimpy Blazer is on a distinguished road
Man, it's like just about anything. It lasts untol it breaks. The better you take care of it along the way the longer it'll last. If you got 128,000 out of a set I guess that's not bad. I think that whenever you get over 100,000 it's just money in the bank.
Old Jan 28, 2010 | 01:35 AM
sparky672's Avatar
I agree, but that wasn't the point of my question.
Before I spend a huge amount of energy changing these donuts, I was just looking for somebody to say something like, "yeah, those things never last more than xx,000 miles" or "they usually blow out before xx,000 miles, so yours are likely gone."
Old Jan 28, 2010 | 07:44 AM
hubert hefner's Avatar
hubert hefner is on a distinguished road
You could try to clean up the nuts so you can get a socket on them and heat it up the the cutting torch get them cherry red and they should come off like butter. I've done that many times.
Old Jan 28, 2010 | 10:30 AM
sparky672's Avatar
Me too.
That's the tentative plan as soon as it gets warmer over here... only about 6 degrees this morning.
Old Jan 28, 2010 | 10:53 AM
Lol. ya its about 10 degrees here...
Old Jan 29, 2010 | 12:45 AM
I can tell you that my donuts were original and had 185,000 miles on them. At least the installation looked original. Knowing the guy who owned this Blazer before me I would almost guarantee it. The donuts were still good. It was the "Y" pipe that was bad. It is kind of a PITA to do this job by yourself but then again it is doable. Just have a lot of patience and don't forget the anti-sieze. A little dab is all you need. I put it on everything that has to do with exhaust.
Old Apr 15, 2012 | 11:18 AM
mjt's Avatar
mjt
mjt is on a distinguished road
Trying to replace the donuts now. Been soaking those studs with PB Blaster and tried some heat. I think I got one stud to turn about a quarter turn. Seems like the stud will come out of the manifold rather than the nut coming of the stud. Just soaked the studs from the back side thru the wheel wells. Any experience is welcome
So anybody have an opinion about Felpro $5.99 at Autozone vs Walker $11.99 at NAPA. They are very different seals. The Felpro looks a little thicker too. Dont want to do this crap again.
Old Apr 16, 2012 | 07:30 AM
mjt's Avatar
mjt
After soaking those studs with PB and heating the nuts red I could not break them with a 3/8 ratchet. So the key was the impact gun. Also the FELPRO is superior to the Walker and half the price.
phatso_99blaz
Headers, Intake, & Exhaust
Apr 8, 2013 03:16 PM
blyndside
Aug 3, 2012 12:21 PM
gashdave
Nov 22, 2009 10:55 AM
bigb94s10
Oct 31, 2007 01:01 PM
wrench
Jun 17, 2007 12:12 AM
