Plastic Radiator Repair
Old Oct 31, 2021 | 11:40 PM
FLHTK's Avatar
FLHTK is on a distinguished road
Default Plastic Radiator Repair
A few months back on either Blaze The Wondercar's 2nd or 3rd trip to the dunes, she developed a radiator leak. Luckily Lake Michigan was able to spare a few gallons to get her home.
Finding the leak was easy as was the repair.
The leak was easy to find.
All better thanks to JB Weld radiator Weld.
The hardest part was taking my dremel to the 2 small cracks and making them bigger.
I took videos but I don't see how to upload them.
The other challenge was the speed at which this stuff hardens. You don't have much time once you mix the epoxy. Now that I know how it works, I probably would have done this repair in 2 stages using half of the epoxy at a time.
All in all this JB Weld product worked great! I think I got it at Advance.
I highly recommend.
Old Nov 1, 2021 | 02:51 AM
I highly recommend.
Good to know!!!
Old Nov 1, 2021 | 07:21 AM
LannyL81's Avatar
Interesting!.....I am on my third radiator and every time the leak has been the seal between the plastic tank and the aluminum core; only way for me to fix is to replace.
Good to read that someone was able to "fix" one of these radiators instead of replacing.
Old Nov 1, 2021 | 07:24 PM
eshaw's Avatar
You can have a radiator shop replace the seal between the tank and core. They look kind of like a valve cover gasket only smaller. I'm lucky, I have the tools to replace my own.
Old Nov 3, 2021 | 02:54 PM
LannyL81's Avatar
I was told in the past by a radiator shop that they could not fit it....although that was quite some years ago....may be the shops have the necessary tools/equipment now.
You have the tools....would like to see what tools are needed to do this.
Old Nov 3, 2021 | 06:35 PM
eshaw's Avatar
I'll get a pic of the hand tools if takes to remove a tank hopefully I can post them. There is also a press that is required to hold the core while the tank is pressed down on the gasket that you mount between the core and tank.
Old Nov 10, 2021 | 07:56 PM
eshaw's Avatar
Here's the basic tools for tank removal and replacement. Bare in mind it takes more than this to do the job. You have to have a fixture that holds the core and tank.
The fixture applies pressure to hold the tank in place while you crimp it back into place. Then you have to pressure test the assembly.
Old Nov 14, 2021 | 07:54 PM
puttster's Avatar
When mine sprung a leak I took it to a radiator shop to get it repaired, he just replaced it.
https://blazerforum.com/forum/attach...diaor-leak.jpg
Old Nov 16, 2021 | 12:17 PM
LannyL81's Avatar
I have watched a video on how the plastic tanks are attached to the core. It showed the machine that held the core and plastic tank in position then did the crimping. All automated of course; was a production facility video.
Will have to continue just replacing the radiator instead of fixing it......thanks for the picture.
benp#38
Jun 29, 2013 04:37 PM
Maniboss
Aug 5, 2010 03:53 PM
88skisupreme
Jun 21, 2010 09:56 PM
freonchill
Nov 18, 2008 02:07 PM
jp
Jun 26, 2006 01:30 PM
