please help!
Old Jan 20, 2012 | 11:35 PM
lprovost's Avatar
lprovost is on a distinguished road
Default please help!
99 blazer 2wd . when i hit the brakes it shuts off. what can this be?!
Old Jan 20, 2012 | 11:50 PM
Rottidog's Avatar
I'd say an ignition/security issue - almost for sure! Do you have a remote starter installed?
With our vehicles if it's started with the remote & you get in & don't put the key in & step on the brake to put it in gear the vehicle will shut off.
Maybe the valet switch has been switched?
Search around in here for Security & Ignition I'd swear that's what's causing it.
Old Jan 20, 2012 | 11:54 PM
xgiovannix12's Avatar
hmm i wonder if the ignition switch would cause symptoms like this ?
have you seen any other symptoms like no dash lights or radio ?
Old Jan 22, 2012 | 09:13 PM
lprovost's Avatar
never had electric start on it. just remote locks. sometimes when i first start it it will start then immediately shut off. after about the third try, it will stay running. but when it does shut off, i lose all radio pre-sets. so its losing all power i guess. battery connections are good and no lose wires. could the brake booster maybe be causing this? im just curious
Old Jan 22, 2012 | 09:17 PM
sounds electrical
check your grounds
get the battery load tested also
read this
Anatomy of the Ignition Switch - Blazer Forum - Chevy Blazer Forums
diagnose the ignition switch its worth a shot
Old Jan 22, 2012 | 09:51 PM
Rottidog's Avatar
The security system is mucking up. Some sort of electrical issue with the security system. It's intermittent so possibly a ground or a short?
opposedforces
Sep 1, 2011 02:59 PM
BlazerPunisher
Mar 23, 2009 05:47 PM
rogggg1020
Nov 11, 2008 08:05 AM
blazin4eva
Feb 26, 2005 12:04 PM
blazin4eva
Jan 27, 2005 02:02 PM
