PLEASE HELP!!! 99 4.3 random misfire codes, rides really rough
Old Feb 26, 2013 | 03:36 PM
kdawg1354's Avatar
kdawg1354 is on a distinguished road
Default PLEASE HELP!!! 99 4.3 random misfire codes, rides really rough
Hey everybody, got a 99 blazer 4.3 which i love. Lemme tell you what its doing: about 3 days ago it started up fine, ran around town for about 3 hours, then it just started sputtering and not running right. Stalls and tries to die when rpms are low, like when shifting from park to drive(or reverse). Ok what ive done so far: replaced sparkplugs, wires, cap and rotor, and distributor(plus cam position sensor). Still runs awful-no change in its behavior. Oh and ive straight-piped in lieu of my cat out of necessity. Ideas? Suggestions? Im stuck and very frustrated! PLEASE HELP!!!
Old Feb 26, 2013 | 03:58 PM
P0300 is almost always caused by a fault in secondary ignition: plugs, wires, distributor cap, rotor and ignition coil. It can also be caused by low fuel pressure and incorrect camshaft retard.
These engines are very fussy when it comes to ignition parts, especially with plugs, (AC Delco 41-993 gap .060") and distributor cap, (AC Delco). If the distributor has been removed, camshaft retard needs to be checked, and probably adjusted.
List all of the DTC's, (diagnostic trouble codes) in the order they were retrieved.
Old Feb 26, 2013 | 07:11 PM
kdawg1354's Avatar
Ok, theres an o2 sensor code thats been there since i bought it 3 years ago. The guy i bought it from said its been like that ever since he put flowmasters on it. so theres that, and the random misfire code, i dont know the number, but its there. So list in order is : oxygen sensor, random misfire, oxygen sensor, random misfire
Old Feb 26, 2013 | 07:31 PM
It makes a difference what the oxygen sensor code is. If it's for the downstream sensor, it will have no affect on engine performance. If it's for an upstream sensor it will make a difference in how the engine performs and could possibly set the random misfire DTC as well. We really need to know the exact DTC's before continuing with the diagnosis.
Old Feb 26, 2013 | 09:38 PM
kdawg1354's Avatar
Ok so the guy at AutoZone was being #@&!ing jerk and wouldn't hook it up to get the codes, he said he didnt think the o2 sensor would cause it to sputter and stall like it is and that its probably a fuel injector cause thats a common problem in those "fo-threes" and tried to sell me some for only 350 bucks(which i dont have). So ima run it up there tomorrow and get somebody worth a crap to diag it. Any ither suggestions?
Old Feb 26, 2013 | 09:55 PM
Sounds familiar.... AZ, Advance & O'Reilly will all check DTC's for free, try another store. The point of DIY is to diagnose it properly BEFORE spending money.
blazerhelp01
Mar 30, 2015 09:36 PM
Kilo
Jul 27, 2013 06:57 AM
JohnnyALCATRAZ
Apr 19, 2011 01:14 PM
EuroGoldLS
Lifting Tech
Jun 22, 2007 03:35 PM
jdblazer
Dec 20, 2006 12:58 PM
