please help with abs malfunction
Old Jul 27, 2013 | 05:06 PM
audio junky's Avatar
audio junky is on a distinguished road
Default please help with abs malfunction
My truck when it warms up after a while it will activate the abs without me breaking hard and then abs light comes on and when I continue driving the speedomiter doesn't show me anything and also at the same time it has trouble shifting ordoesn't know when to shift and is getting worse also I've been told it might be the abs module but others think it's the wheel speed sensor or abs sensor please help
Old Jul 27, 2013 | 05:29 PM
Thogert's Avatar
The new member area is for introductions only.
**Moved to 2nd gen tech**
On that note, it sounds like your speed sensor on the output shaft of the transmission has gone bad, or has a bad connection. That is where the abs gets its reading from the rear tires and where the speedometer and trans gets info from as well. That's where I'd start looking.
Old Jul 27, 2013 | 05:59 PM
newguy's Avatar
I thought the abs sensors where only on the hubs, and speedo on the tranny. I had trouble with my abs, put in a new passenger hub with sensor and the light went off. The old one was cracked and loose. Front wheel hubs/ sensors only, nothing on the back.
Old Jul 28, 2013 | 01:58 AM
Thogert's Avatar
The only speed sensor for the rear wheels is the VSS located on the trans. I am quite sure it feeds the abs module as well.
Old Jul 28, 2013 | 05:41 AM
BMWDr's Avatar
BMWDr is on a distinguished road
Thogert is spot on. The rear doesn't have sensors on each wheel as it has a solid axle connecting both wheels and the safest most protected place is at the rear of the trans. It uses the driveshaft rotation to determine rear wheel lockup as well as vehicle speed for speedo, cruise control and transmission function.
Old Aug 13, 2013 | 04:47 PM
zman6988's Avatar
zman6988 is on a distinguished road
I have ABS code that reads no signal from rear ABS. So is it possible for my speedo to still work but not send a signal to my ABS? Because everything works on my dash but the ABS light is still on and that is the only code.
Old Aug 13, 2013 | 05:25 PM
Diaita's Avatar
May be an intermittent problem, but the code is still there.
steelcityneal
34
Oct 6, 2017 06:10 PM
builder125
May 20, 2013 06:51 PM
RoxStar33
Dec 21, 2012 08:28 PM
jrl2282
Dec 23, 2006 11:12 AM
