please help asap
Old Dec 8, 2012 | 11:17 AM
engbulldog's Avatar
engbulldog is on a distinguished road
Default please help asap
hello guys and gals , new to the board and in need of some help
1. I own a 1998 GMC jimmy 4x4 sle, 4dr
bought if from my parents so I could store my summer ride during the winter, last week before work I started it up and seen that no gauges worked for about 10 sec then all was fine, started to drive it and it would not shift out of second , called a pal and he tells me to unhook the battery for a hr to reset the ecm, he said it went into a reduced power mode, he came over a few days later to scan the codes, had an LF wheel speed sensor open (knew that) the other codes were gone do dis-connect of battery, last night @ 11pm in the rain the jimmy did the same thing , hence dis connect battery for hr. and drove the beast home what is causing the mystery problem, I dont have a tech 2 to scan the codes and the dudes at auto zone couldn't butter bread let alone tell me what code it is ?? thanks in advance
Old Dec 8, 2012 | 12:13 PM
Diaita's Avatar
ignition switch.
Old Dec 8, 2012 | 12:14 PM
1sttimejimmyowner's Avatar
1sttimejimmyowner is on a distinguished road
Im taking a shot at this check your tps sensor.
Old Dec 8, 2012 | 03:07 PM
50lb_cat's Avatar
Is the security light on?
Old Dec 9, 2012 | 08:37 AM
engbulldog's Avatar
no just the service engine, and my ABS (which I know about)
my friend is saying it might be a corroded wire behind the right kick pad, note the jimmy has 196 k on it
Old Dec 9, 2012 | 01:08 PM
Gotta pull the DTC's and post them. I agree with Diaita on the possibility of a faulty ignition switch. This link will help in diagnosis: https://blazerforum.com/forum/articl...-switch-33465/
Disconnecting the battery, for any length of time, will not "reset" or clear any DTC's from the memory files, (pending, current & history) basically it's a waste of time. It will turn the SES light off only if there are no current hard faults present.
Old Dec 10, 2012 | 08:25 AM
engbulldog's Avatar
thanks for the help, waiting for my buddy to come over and scan it for me
Old Dec 10, 2012 | 10:49 AM
engbulldog's Avatar
ok went to autozone and picked up a Duralast ignition switch parnt # ls948 I hope this is what causing the problem any diagrams out there on how to install this?
Old Dec 10, 2012 | 11:28 AM
burned's Avatar
burned is on a distinguished road
https://blazerforum.com/forum/tech-a...-method-36967/
https://blazerforum.com/forum/tech-a...acement-29167/
Old Dec 10, 2012 | 03:57 PM
What DTC's are in memory?
Did you diagnose the ignition switch as being bad, or are you guessing/hoping?
