Po174 & po154
Old Aug 3, 2010 | 09:20 PM
blazerJim1701's Avatar
blazerJim1701 is an unknown quantity at this point
Default Po174 & po154
I'm getting these codes ONLY when the A/C is used.
No Codes when the A/C is not used.
I've changed the AIC And the TPS Sensor.
Replaced the Spark plugs. Wires good, replaced last year and the distributer replaced also.
She idles great when the A/C is not used, the idle was bad before replacing the AIC and TPS.
And yesterday when I was going to the store the CEL light up and started blinking, that is WITH the A/C on.
Just came back from store today and did not have A/C on, no problem...
Thx
Jim
Old Aug 4, 2010 | 06:21 AM
Code sheets:
P0154 - HO2S Insufficient Activity Bank 2 Sensor 1
P0174 - Fuel Trim System Lean Bank 2
I'm not sure why these codes would only come up when using the A/C, but you could have a short somewhere in the wiring between the two systems...
Old Aug 4, 2010 | 07:36 AM
Thx Kyle,
I had 2 new o2 sensors installed like a year and a half ago, I know they were not AC delco but I know they weren't bosh either.
could it be the autolite spark plugs I put in about 3 months ago? Prior I had the cheapest AC delco's in then decided to install new autolite's.
AND this morning I cleaned my egr valve just in case, I installed a new one like 18 months ago.
JIm
Old Aug 4, 2010 | 03:44 PM
Ok, I figured out the problem myself.
I installed autolite double plat about 3-4 months ago and she ran good until I put a new AIC and throttle positioning sensor on. you do have to agree at around 160K miles it's time.
That is when my she started throwing codes with the AC ON, off she was fine.
So today i went to advance auto and bought AC Delco rapidfire platinum and installed them.
idles nice with the AC on. took it for a ride and still idling nice.
Did notice that the autolites were longer than the ac delco and when i pulled the autolites they had a slight red or orange hue to them, what does that mean?
So this just tells me AC Delco all the way....
jim
Old Aug 4, 2010 | 05:34 PM
The hue could just be discoloration due to heat.
Where were the Autolite plugs longer? If external, that wouldn't matter. I used to like Autolite plugs in my older vehicles, but their quality isn't there anymore.
Old Aug 4, 2010 | 05:41 PM
the treads were longer, I matched up the first one to the new ones and the autolites were longer internally.
I found that weird.
but the new ones are in and it seems like a-ok.... hopefully.
one question as a preventive maintence measure and at the blazers mileage do you think I should replace the VSS sensor?
I have to replace my rear shocks asap and while im under there I was thinking of replacing the vss.
Jim
Old Aug 4, 2010 | 06:16 PM
VSS as in Vehicle Speed Sensor? There would be no reason to replace it as preventative maintenance. Maybe clean it, but you don't have to go nuts.
Old Aug 4, 2010 | 07:58 PM
oh, ok I'll clean mine, I just thought that with 160K miles it might be wearing out?
But if it just a cleaning then I'll do that
BTW kyle, if an engine runs too rich will not the spark plug have black soot on them?
Thx
Jim
oldmechanic
Aug 7, 2014 08:29 PM
Dobe Rottie Gang
Dec 6, 2013 10:04 PM
jkhabel
Aug 27, 2011 03:03 PM
luvcycles2
Jan 22, 2009 12:03 PM
Jetfixer
Oct 1, 2008 06:13 AM
