Po452
Old Jul 19, 2012 | 07:20 PM
jim109's Avatar
jim109 is on a distinguished road
Default Po452
Changed fuel lines now get 452 code?
Old Jul 19, 2012 | 09:46 PM
Here's the flow chart for P0452, follow it and you'll find the problem:
https://blazerforum.com/forum/diagno...plained-35142/
Old Jul 20, 2012 | 09:53 AM
jim109's Avatar
When i open the gas cap i dont hear any air escapeing like i use to.I didnt fill the gas tank when i put it back in only about 5 gals would that make adifference ? i checked all tcnnections all seems right .doesthat code 452 mean its only electricical?
Old Jul 20, 2012 | 10:40 PM
With this EVAP system, you should never hear pressure or vacuum when removing the fuel filler cap. The DTC is indicating a problem with the fuel tank pressure sensor or its circuits.
Old Jul 24, 2012 | 01:37 PM
jim109's Avatar
Thanks Capt Hook Took off connector & cleaned it re connected & light went out i hope it stays out .Thanks again for setting me straight... Jim
Old Jul 24, 2012 | 03:07 PM
You're welcome, glad you got her fixed. Thanks for posting back!
Old Oct 9, 2012 | 04:50 PM
mcdowell's Avatar
mcdowell is on a distinguished road
I'm sorry to bring back an old thread but I'm having p0452 issues and i was looking around it looks like the metal line from the tank up to the engine is leaking would that be able to cause a p0452? its confusing because its only an issue in the morning time/not up to operating temp. either way obviously i gotta fix it but I'm hoping i can stop racking my brain over this now.
thanks in advance
Old Oct 9, 2012 | 07:58 PM
P0452 is an EVAP DTC indicating there is a fault in the fuel tank pressure sensor, (located on top of the fuel tank) or its circuits. If the steel line is 3/8", (fuel pressure) or 5/16", (fuel return) it will leak liquid fuel when the engine is running, it will not set any DTC's. If the leaky line is 1/4", it is the vapor line for the EVAP system and will only leak fuel vapor, (or vacuum while the system is testing or purging). A leak in this line will cause P0440 and or P0442.
wlorton
Jun 7, 2013 09:01 PM
kevlar974
Sep 11, 2011 08:59 AM
