Poor Traction in Rear Wheels...
Old Nov 12, 2008 | 02:35 PM
bobbyj42's Avatar
bobbyj42 is an unknown quantity at this point
Default Poor Traction in Rear Wheels...
I have a 2001 two-door 2WD. I have 2 brand new rear tires...but whenever the roads are even slightly wet, my tires spin like crazy when I have to jump on the gas. It's getting to be pretty dangerous because it's hard to get up to speed...it's almost like I'm on ice. I've even had the rear end fishtail around on freeway on-ramps. Any ideas why this may be?
Old Nov 12, 2008 | 02:38 PM
Default RE: Poor Traction in Rear Wheels...
What kind of tires did you go with? The tire compound is probably pretty hard, making it skate around...
Old Nov 12, 2008 | 02:42 PM
rriddle3's Avatar
And what pressure did you put in them?
Old Nov 12, 2008 | 02:48 PM
WolfPack's Avatar
Also if theyre brand new, the lubricant/oils used in the tire making process take a few hundred miles to work out. My tires came with a warning about the first break in period and possible loss of traction.
Old Nov 13, 2008 | 07:57 AM
bobbyj42's Avatar
ORIGINAL: swartlkk
I'm not sure the exact model...just some basic Goodyear truck tires. I usually run my tires at about 4 or 5 lbs less than the psi suggested on the tire due to the expansion when the tires heat up.
I'm going to get snow tires for this winter...is it worth it to get all four or just the rear?
Old Nov 13, 2008 | 08:10 AM
salvy's Avatar
salvy is an unknown quantity at this point
Put some weight in back till you break them in, and/or maybe burn'em out a bit, get the top layer to soften up. try that, I know their new but I'm sure it won't kill'em.
Old Nov 13, 2008 | 09:22 AM
portcqb's Avatar
portcqb is an unknown quantity at this point
You can try scrubbing down the tires with good car wash to get the production oils off. Most likely if they are basic they are a poor traction hard compound.
BlackMatter
Feb 16, 2012 10:27 PM
Dbam31
Tires and Wheels
Jan 22, 2010 03:22 AM
kmartin
Oct 4, 2008 04:21 PM
Coyote
Sep 2, 2008 07:13 AM
02 Vortech
Headers, Intake, & Exhaust
Jun 30, 2005 06:42 PM
