Popping Sound / Overheating
Old Aug 14, 2013 | 01:40 PM
rza0122's Avatar
rza0122 is on a distinguished road
Default Popping Sound / Overheating
Hi, my 1997 Blazer is frequently heating up so much that the gauge points into the red. I can turn on my heat and it will usually cool it down, but not always. I hear a popping/clicking sound behind my dash and then the temp goes down. Anyone have an idea of what might be causing this? Sounds like something isn't opening as it should to let out the engine heat. Any help is appreciated. I'd like to fix this myself. Thanks!
Old Aug 14, 2013 | 01:46 PM
chris015's Avatar
sounds like thermostat is sticking shut. Keep driving like this and you'll be replacing that motor. Check your oil,if its milky coffee creamer put a fork in it. its done.
Old Aug 14, 2013 | 01:51 PM
rza0122's Avatar
So I should change the thermostat, and if the oil is milky like coffee creamer I should change the oil?
Old Aug 14, 2013 | 01:57 PM
chris015's Avatar
First off,check the coolant level.
Yes first step would be to change the thermostat with a new gasket. Put a thin layer of waterpump sillicone on each side of the gasket.
If the oil looks like coffee with coffee creamer,the engines done. Either cracked heads,head gasket etc.
If the oils like this theirs no telling how long you've been driving with water in the oil,the bearings etc may be wore out from the water mixing with oil. id advise have engine replaced by a qualified mechanic.
DaddysBlazer
Mar 6, 2012 06:56 AM
orangeshamrock
Jun 17, 2008 07:56 PM
ChicagoBlazer
Feb 16, 2007 05:44 PM
grendragginbu
Jan 26, 2007 03:04 AM
Mike
Aug 23, 2005 11:49 AM
