Posi lock not working
Old Jul 4, 2009 | 07:25 AM
ftwflh's Avatar
ftwflh is an unknown quantity at this point
Default Posi lock not working
I did this conversion(https://blazerforum.com/forum/tech-articles-diy-29/how-homemade-posi-lock-cable-system-31138/ ) on a 1997 Blazer.
and you can hear the axle click in but when testing you get no power the front wheels.
Is there anything else to check?
Thanks Brad
Old Jul 9, 2009 | 06:07 AM
ftwflh's Avatar
bump up for help
Old Jul 9, 2009 | 08:40 PM
It is possible that you have a problem internal to the front axle. You can check to see if the front axle is engaging by jacking up the passenger front wheel, leaving the driver front on the ground. With the transfer case in 4HI or 4LO and the front axle engaged, try to turn the passenger wheel. If you hear/feel clicking, then the collar inside the front axle is not properly engaging the passenger side axle. If the front driveshaft turns, then the transfer case is not properly engaging 4wd.
mysons95
56
Nov 18, 2021 09:35 PM
big_charms@hotmail.com
Mar 20, 2014 10:26 PM
rdhack
26
Aug 6, 2011 08:21 PM
smokey94
Jan 16, 2010 10:44 AM
jimhens82
Oct 31, 2009 02:28 PM
