Possible leak at air intake duct
Old May 21, 2014 | 06:30 AM
kelcan's Avatar
kelcan is on a distinguished road
Default Possible leak at air intake duct
Is there a way to tighten down the metal clasps at the front of the air duct that connects to the top of the throttle body? I have a vacuum leak and know these systems are very sensitive. I can see a small space at the front between the duct and body that I think could be letting air in, but I wonder if I have to replace the whole duct or if there's a way to tighten down those metal clasps.
Old May 21, 2014 | 04:32 PM
spittybays
Guest
Posts: n/a
Your air intake and a vacuum leak are two completely different things. If you have trouble with your intake clamp just duct tape it. Vacuum leak is a problem that needs to be tracked down.
Old May 21, 2014 | 11:27 PM
Thogert's Avatar
You can find a vac leak by spraying brake cleaner around your vac lines. If, when you spray a line, the engine revs higher, that's where your leak is.
Old May 22, 2014 | 03:30 PM
spittybays
Guest
Posts: n/a
There are two kinds of brake cleaner, one is flammable one is not. Make sure you get the flammable one. The non-flammable is chlorinated and exposed to heat will make something very similar to mustard gas and kill you!
Old May 24, 2014 | 03:48 PM
Thogert's Avatar
Good point. Missed that one.
Old May 24, 2014 | 04:06 PM
spittybays
Guest
Posts: n/a
Yea well this was learned by experience. I was trying to pop out a bearing with heat and so called "liquid air". The stuff you blow out computer boards out with. Well I figured, smart guy that I am, you turn it upside down and spray it on hot metal should work pretty good.
Wrong, ambulance ride and ventilator for three days.
Still argue with the wife that I don't have brain damage.
She is most defiantly wrong!
Well she might be correct, who the heck knows, I might have brain damage!
How do you tell?
Old May 27, 2014 | 11:28 PM
Thogert's Avatar
I used to play with that stuff and fire when I was younger, didn't get an ambulance ride though... Feel like I did it wrong now...
hoebob69
Feb 1, 2015 10:07 AM
newguy
May 13, 2013 04:20 PM
upmaine
Apr 15, 2010 06:52 PM
Don,t no much
Jan 30, 2010 02:48 PM
lcars
Dec 19, 2005 03:18 PM
