power door locks not working
Old Aug 23, 2013 | 01:11 PM
M_Theory's Avatar
M_Theory is on a distinguished road
Default power door locks not working
hey guys, i have read over 20 threads on this subject but havent been able to get anywhere. Power door locks did not work when i bought my 95 blazer. so i replaced the switch as it looked old and worn. still nothing, so i went on to replace the relay. again still no locks. All fuses in the side of the dash are good. what else can i do? what can i check
Old Aug 24, 2013 | 05:24 PM
go-part's Avatar
Former Sponsor
go-part is on a distinguished road
Old Jan 28, 2021 | 10:09 AM
djbillyd's Avatar
djbillyd is on a distinguished road
Default PWR DR LK Not working
I've an 02 Blazer 4 DR 4WD, and just today, the door locks are not working. I checked the fuses (13, 14) and they were good. I looked for a relay rack behind the glove box, and there was none. What looked like a radio antenna box was there, and above that was the dash duct work. I haven't checked to see in the windows are working. It's 35 degrees today and I got running around to do. But the door locks don't work. I manually locked them to see if they will stay locked, but this is something that needs to be repaired, and right now, I am my best choice for a mechanic Been outta work for a year now.
Old Jan 28, 2021 | 10:29 AM
GeorgeLG's Avatar
Let's get you working again. There are 3 fuses and 3 relays:
Mir/Lok fuse 7, 3A (UHFB)
Pwr Lks Fuse 14, 15A (IP fuse blk)
TRC fuse 10A, UHFB
3 relays: behind lft side dash near IPFB
Is it both lock and unlock and both door switches that are faulty?
Does the remote work?
George
Old Jan 28, 2021 | 10:32 AM
djbillyd's Avatar
Found the issue, with mine at least. In the under hood fuse box, there is a 3 AMP fuse, the MIR/LKS, to the left of the LIFT GLASS and FOG LP relays. The 3 AMP fuse sits directly above a 15 AMP fuse for FOG LPS.
I had a spare 3 AMP in the spare fuses on the right side of fuse panel.
Old Jan 29, 2021 | 04:31 PM
djbillyd's Avatar
TRC fuse 10A, UHFB
George
LOL! It's funny, you were replying while I was outside fixing the fuse problem. We literally did that at the same time!
Thanks anyway.
Old Apr 27, 2022 | 06:12 PM
ECMECH58's Avatar
ECMECH58 is on a distinguished road
Default 99 blazer locks
TRC fuse 10A, UHFB
George
no remote. 99 blazer door locks. i have checked and replaced all 3 fuses even though they looked OK. Did power drops on both sides of all fuses and still no luck. Replaced the relay block thinking an internal issue. No luck. Replaced one relay with a new one. Moved it around to the other 2 spots, no luck. Did voltage checks on the back side of both switches. Power was present, no luck. Power is making it to relay block. Not sure if it's going out to the actuators because of the poor location of relay block, can't get a good read on wires. All 4 locks and the lift gate went out at the same time. Can't find g201 and g200 ground connections iaw schematic.
It HAS to Be a common point problem. ANYONE have a clue?
Old Apr 27, 2022 | 09:55 PM
GeorgeLG's Avatar
The truck did not come with a remote, you lost the remote or the remote also does not work along with any combination of door lock/liftgate buttons and switches?
George
Old Apr 27, 2022 | 10:16 PM
ECMECH58's Avatar
George
I found the problem. There was no difference of potential on the passenger door lock switch. It was caused by a powerfeedback between the master switch and the passenger switch. I pulled the switch and saw the corrosion had bridged the contacts creating the feedback short.
Old Apr 27, 2022 | 10:19 PM
GeorgeLG's Avatar
Glad you found it
George
JDCosby
Sep 17, 2015 03:15 PM
NCSurvival
Sep 13, 2014 06:16 PM
nitrally
Sep 7, 2012 05:55 PM
Chenzo
Jun 25, 2010 08:49 AM
Elisha
Mar 14, 2006 08:50 PM
