Power Lock Problems
Ok, another issue to log... My prower door locks are jacked. My "Better half" left the windows down and it started raining hard. She closed the door (after putting the windows up) and the doors locked them selfs. she opened the door with the key, and as soon as she opened the door...it locked again. Now here is the i pulled the fuse so now we are in manual mode. However, as soon as you apply the fuse...they lock up again. And giving the fact that the lift gate runs off the same system.. that to is locked shut... I'm frustrated beyond belief now. Any ideas?
Also, with the fuse in...the locks are held in the locked possition. Tried pushing the unlock button...I can here them trying to unlock, but all four doors stay secured. The key fob has same results.
well, i fixed the problem. It turned out to be wet and corroded at the connection between the switch and the wiring harness. Sprayed it with electrical cleaner (Chemsearch) and then blew it out with compressed air. repeated three or four times...and by George it worked!
NoFlopScott
07-21-2014 04:09 AM
derrblazer
05-20-2009 10:16 AM
muszyngr
04-08-2008 01:24 PM
