Power Mirror switch question
I ckecked the fuse box under the hood and the fuse is OK. Could the switch just be bad and not sending a signal to mirror motors ? The switch has the lights working but thats it.:icon_doh:
Thanks |
On the mirror switch connector check from the orange wire to a ground for 12v (with the key on). If you have that check from orange to the black wire in the connector for 12v. If you have that order your switch.
common problem. windows are at a bad angle lots of water gets in
over time, corodes connections. pop it off and clean with rubbing alcohol and a pencil eraser. you = FTW! |
My drivers window is the victim of that... I clean that switch once a year.
Thanks for the info, I'll try that fix and get back to you all.....
