Power Mirror switch question
Old Nov 28, 2009 | 06:36 PM
JohninMass's Avatar
JohninMass is on a distinguished road
Post Power Mirror switch question
I ckecked the fuse box under the hood and the fuse is OK. Could the switch just be bad and not sending a signal to mirror motors ? The switch has the lights working but thats it.
Thanks
Old Nov 28, 2009 | 06:58 PM
RonJon's Avatar
RonJon is an unknown quantity at this point
On the mirror switch connector check from the orange wire to a ground for 12v (with the key on). If you have that check from orange to the black wire in the connector for 12v. If you have that order your switch.
Old Nov 28, 2009 | 07:03 PM
ABN31B's Avatar
common problem. windows are at a bad angle lots of water gets in
over time, corodes connections. pop it off and clean with rubbing alcohol and a pencil eraser. you = FTW!
Old Nov 28, 2009 | 07:14 PM
RonJon's Avatar
My drivers window is the victim of that... I clean that switch once a year.
Old Nov 28, 2009 | 09:14 PM
JohninMass's Avatar
Thanks for the info, I'll try that fix and get back to you all.....
coiley
Aug 15, 2011 08:16 PM
Wexinlo
Apr 6, 2011 11:35 PM
JohninMass
Nov 30, 2009 08:24 AM
JohninMass
Nov 26, 2009 12:51 PM
George
Apr 18, 2008 11:15 AM
