-   -   power side mirrors dont budge (https://blazerforum.com/forum/2nd-generation-s-series-1995-2005-tech-41/power-side-mirrors-dont-budge-80208/)
er0ck273 Jul 3, 2013 07:21 PM
i have power side mirrors, one is oem the other is aftermarket, they look exactly the same lol. my question is, with using the controls on the drivers side door to adjust them neither of them work. and i turn the one button left and right (to switch mirrors to control) and neither of them work. how can i tell if its the button?
warthogdriver Jul 3, 2013 08:42 PM
Mine did the samething...the lock out switch had corrosion on it...a little emry cloth on the contacts and was good to go.
Captain Hook Jul 3, 2013 08:48 PM
If the power locks work, the fuse for the mirrors is good. (Instrument panel fuse block, fuse #7, must have battery voltage at all times on both terminals of the fuse.) On the back of the window switch, the orange wire must have battery voltage at all times. The black wire must show less than 5 ohms resistance to ground at all times. Post your results.
FYI: if the window is open when it rains, water drips onto the switch causing the contacts to corrode, which destroys the switch.... not cheap ;)
er0ck273 Jul 3, 2013 09:20 PM
good advice thanks guys, yeah the power locks work fine. i loaned my buddy my multimeter ill have to get it from him friday and as soon as i get it i will post results, in the meantime ill grab some emry cloth at the contacts, i found a new switch on ebay 34 free ship if it comes down to it...i hope not lol
Toby Hanson Jul 4, 2013 01:16 AM
Be sure and do a good job of troubleshooting your switch before you order a new one. The switch in my '98 Jimmy was working intermittently. I decided not to do any troubleshooting and bought a used replacement from eBay. The replacement switch didn't work at all.
er0ck273 Jul 4, 2013 01:36 PM
oh yea theyre way too expensive to not do the proper troubleshooting haha
