power window motor
Old Jan 26, 2012 | 05:14 PM
darknight's Avatar
darknight is on a distinguished road
Default power window motor
Just how hard is it to replace a bad window motor in a driver store...????
Old Jan 26, 2012 | 06:15 PM
pettyfog's Avatar
Piece of cake. You have to remove the switch panel first then the door panel. All downhill and cussing from there on.
Of course if you never removed door panels before it is a flamin' beeyatch!
so.. is that who you're asking.
You know they probably have a couple videos on youtube that would give you an idea.
Old Jan 26, 2012 | 06:18 PM
xgiovannix12's Avatar
real easy this should explain the whole process
Diagnosing and replacing a power window motor
I WARN YOU
if you dont drill the window regulator and put a bolt serious injury can occur
DO NOT REMOVE THE MOTOR with out doing this step
Unless you wanna loose a few fingers
for example
chevrolet blazer s10 gmc jimmy window motors replacement very unsafely way - YouTube
do not follow this idiots actions he was lucky he still has his fingers
Old Jan 27, 2012 | 03:06 PM
darknight's Avatar
Thanks guys
Old Feb 2, 2012 | 10:25 AM
my2k2zx2's Avatar
my2k2zx2 is on a distinguished road
Our 99 Blazer driver front door motor quit. I took off the door panel and tapped the motor with a hammer and it started working. Havent had a problem since. (about 6 months ago or so.)
Old May 15, 2012 | 02:25 AM
meatbag's Avatar
meatbag is on a distinguished road
When that guy put his head over the assembly,,, I got kinda scared for him. That thing really kicks if you don't drill a hole in it to lock the 2 pieces together, prior to removing the motor! He is WAY luckier than I think he realizes!
Old May 15, 2012 | 12:20 PM
I agree
Old Jul 30, 2012 | 08:07 AM
Echeban's Avatar
Echeban is on a distinguished road
Thumbs up
Originally Posted by my2k2zx2
Our 99 Blazer driver front door motor quit. I took off the door panel and tapped the motor with a hammer and it started working. Haven't had a problem since. (about 6 months ago or so.)
AMAZING !!! I just did the same on my 99 Blazer LS and it worked !!! ... this is MAGIC !!!
Old Dec 18, 2012 | 01:08 PM
MikeTastic's Avatar
MikeTastic is an unknown quantity at this point
I WARN YOU
for example
I have a question. On page 8, they say replace The motor using rivets or bolts.
Well I don't have a rivet gun and there is no room to get the head of a bolt or
A nut on the back side of the frame because there isn't enough room in between
The gear and the mounting bracket. I have that problem for 2 of the 3 holes.
Old Dec 18, 2012 | 01:19 PM
all the window motors I did I never had issues with the bolts... IM not sure what your talking about. It sounds like the bolts are a little to long if I understand correctly.
