Power window roller problem
Old Mar 27, 2013 | 09:21 AM
Adamhon11's Avatar
Adamhon11 is on a distinguished road
Default Power window roller problem
The driver's window on my 1999 Blazer is off track, I took off the door panel and saw that one of the arms pulled out of the roller on the track. I pushed it back in, sprayed some silicone grease in the tracks and worked the window up and down a few time. It worked fine so I put the door panel back on and now it is doing the same thing again. Did I just not push the arm into the roller hard enough, should it pop in or do I need to replace something? Also, what would cause this, I have read that there are guides for the window, could one of those be bad and cause this? If so, where are they so I can check them?
Thanks for any help.
Old Apr 16, 2013 | 02:24 PM
Adamhon11's Avatar
Any ideas?
Old Apr 16, 2013 | 04:50 PM
Spree's Avatar
Spree is on a distinguished road
If your arm is pulling out of the roller, check to see if the arm is worn, if that look's ok maybe you have a worn roller? Just guessing here, haven't had any window problem's yet.
NOs
Sep 1, 2016 12:09 PM
Manteray
Apr 12, 2010 04:36 PM
stlarry
Apr 21, 2009 12:20 PM
97ssblazer
Performance & Brainstorming
Feb 7, 2009 09:36 PM
1996BZR
Engine & Internal
May 18, 2006 12:39 AM
