PP 128 low temp
Old Oct 1, 2020 | 09:45 PM
puttster's Avatar
Default PP 128 low temp
Water temperature has dropped to about 150° and stays there. SES came on, P0128.
because the temp does not rise to normal i'm thinking it's a bad sensor. Am I thinking right?
Okay, now where is it?
Old Oct 2, 2020 | 12:46 AM
AJBert's Avatar
Try pulling your thermostat and see if it wide open first. When they fail, they fail in the open position and will cause low coolant temps. Cheap and easy fix if that is the problem.
Old Oct 2, 2020 | 08:54 AM
puttster's Avatar
I was thinking when the thermostat is wide open the temp holds at 195, not 150, so I figured an open thermostst was not the problem.
Old Oct 2, 2020 | 09:28 AM
You would be incorrect. It does sound like a bad thermostat. Do you have a non-contact thermometer? If you do, verify that the engine temp is actually 150 degrees when it's warmed up. If it is, replace the thermostat.
Old Oct 2, 2020 | 02:37 PM
LesMyer's Avatar
I had this happen a while back. It was the thermostat.
Old Oct 2, 2020 | 05:03 PM
puttster's Avatar
Thanks, y'all, good idea with the noncontact thermometer. I used it and temp at stat housing was 193.So it must be the sensor? Which one and where is it?
Thanks in advance
Old Oct 2, 2020 | 09:13 PM
LesMyer's Avatar
Driver's side head near rear spark plugs
Old Oct 3, 2020 | 04:55 PM
puttster's Avatar
Holy cow what a bitch to get out, IF POSSIBLE.I wish it WAS the thermostat. I'm quitting for now, the sensor is still in there but so is the coolant(!) so at least I can drive.
Old Oct 3, 2020 | 07:01 PM
Soak it with wd. And try after the engine is warm, it might break loose easier.
Old Oct 3, 2020 | 08:03 PM
puttster's Avatar
Got to get a wrench on it first. It's way down in there.
