Prestone flush kit?
![Question](https://blazerforum.com/forum/images/icons/icon5.gif)
Hi all,
What is your preferred method for draining and flushing the cooling system on our 4.3l motors?
I was going to use the block drain plugs to do a proper draining but I could not see how to get to them. As such in order to get the old coolant out I'll have to do a system flush.
Is there a way to do this without the Prestone Flush kit? I ask as I just don't like cutting into my heater hoses to install that Tee connector.
Thanks,
Christine
Thanks,
Christine
The final challenge is how to only use distilled water in the flush. My household water is pretty hard.
Thanks!
And CLR won't mess up anything?
I don't know what adverse reaction the CLR may have to the cooling system's radiator, hoses, heater core, heater hoses, engine block , water pump, and other parts. I would use a known and tested product like Prestone flush in a yellow bottle you buy at your favorite auto parts store. Follow the instructions on the label to the letter. I would hate for you to have to replace all the afore mentioned parts. A bottle is only $2.63 USD at Walmart. There is also a Prestone radiator flush KIT which splices into the heater hose. I am suggesting that you use the bottle flush product.
https://www.google.com/search?q=pres...+flush&ie=&oe=
ComputerNerdBD
05-12-2010 10:48 PM
ComputerNerdBD
04-19-2010 11:43 AM
ComputerNerdBD
11-14-2009 11:48 AM
ZR 2
12-04-2007 03:53 AM
