problems with front wipers
Old Aug 21, 2010 | 09:35 PM
iloveblazers's Avatar
iloveblazers is on a distinguished road
Default problems with front wipers
I was seeing if they worked, they would only turn on when i sprayed the windshield washer fluid. Wouldn't turn on when i turned them on.
Then when i sprayed the windshield with the washer fluid, they started to turn on then stopped. Now they dont do anything.
My dad thinks its a electrical problem but i think its a bad motor.
Any suggestions?
Old Aug 22, 2010 | 01:24 AM
helo's Avatar
helo is on a distinguished road
multifunction switch goes bad sometimes. You need a steering wheel puller to get to it (junkyard switch will be cheap [$5-$10] if you can find one that hasn't been in the rain/snow).
motor also goes bad sometimes.. =).
See the last 5 pages of GM's service manual (page 1498 of the PDF). Use the download link to get the entire PDF: http://www.scribd.com/doc/12986652/1...-Repair-Manual
Old Aug 25, 2010 | 01:31 PM
jwz28454's Avatar
jwz28454 is on a distinguished road
hve a look on page 2 jwz28454,i had a similar problem it might help
Old Aug 25, 2010 | 02:27 PM
Ryanmatt135's Avatar
Ryanmatt135 is an unknown quantity at this point
check this out - my wipers didnt work all the time either, until i did this.... https://blazerforum.com/forum/tech-articles-diy-29/fix-cold-solders-wiper-motor-36236/
Old Aug 25, 2010 | 03:45 PM
737mechanic's Avatar
737mechanic is on a distinguished road
Had the same problem I did the same thing Ryanmatt135 pointed too and it fixed me up.
Old Oct 4, 2010 | 06:55 PM
i just put in a new turn signal switch and a new wiper motor and neither fixed the problem. It turns out that the wires above the wiper motor got fused together because of a blown exhaust gasket. Once we peeled the wires apart the wipers worked correctly lol
flmeade
Feb 2, 2012 02:22 PM
Jonas
Aug 9, 2010 06:29 PM
male1956
Oct 4, 2009 10:01 AM
scoot
Jan 11, 2005 02:38 AM
