Problems starting; constant hydrolock?
Old Jan 5, 2011 | 10:17 PM
TDawg's Avatar
TDawg is on a distinguished road
Default Problems starting; constant hydrolock?
My 1995 Blazer 4x4 wouldn't turn over. tried jumping it, no go. Starter wouldn't turn flywheel. Replaced starter, still wouldn't turn over. Pulled plugs and turned by hand and gas POURED out of the cylinders. Replaced fuel injector, and ran fine for a few days, now it's doing it again!! Any suggestions?
Old Jan 7, 2011 | 04:38 PM
Recon's Avatar
Recon is on a distinguished road
sounds like you have another internal fuel leak, I'm assuming that you have the nightmare cpi engine like I do, I locked mine up last night, I gonna take out the plugs tomorrow and see what happens, you probably have a leaking nut kit. if so, then don't make my mistake and get used ones, always buy new. I'm sure that's your problem assuming that you purchased a brand new injector, its not likely that it went bad that soon.
Old Jan 8, 2011 | 07:22 AM
LannyL81's Avatar
When you state replaced fuel injector, did you replace the entire assembly including regulator?
Did you pull the plugs out and still have fuel pouring out of all cylinders or just one, two?...with the new injector assembly?
Old Jan 9, 2011 | 02:53 AM
TDawg's Avatar
the passenger side plugs were all dry, the drivers side were all wet. the fuel injector includes the fuel regulator; it's a spider design all-inclusive. we're thinking a sensor problem since it seems to be isolated to the driver's side.
flipzat
May 2, 2011 11:59 AM
juniorskates99
Nov 25, 2009 10:13 PM
v8dan
Jan 29, 2009 10:01 AM
jman_08
Jul 9, 2008 09:19 PM
boomb1
Mar 30, 2008 12:42 PM
