Program key fob entry key europe model - help!
Old May 11, 2012 | 04:09 PM
changeme20's Avatar
changeme20 is on a distinguished road
Default Program key fob entry key europe model - help!
hi
i have a blazer 99 europe model, i have searched through past posts on re programing the entry fob, but to no luck as it still does not work.
so i have the 5 digit code, as i use this code to start the blazer at the min by the series of key turning and programming the 5 digit code via the fog switch, does this mean the passlock 2 system is ok?
my questions is when do i program the entry fob in this system and how, as nothing seems to work, this is what i do
replacement fob has the same gm number on the back as old one which stopped working one day, number is GM/UTA 15732810
can someone tell me where in the sequence when i program the fob
1. key in ignition
2. press and hold door power button
3. on, off, on, off with ignition key
4. release power door button
5. security light comes on
6. enter via fog switch first number of 5 digit code
repeat until all 5 digits are inputed
7. blazer locks and un locks doors
8. I can now start the blazer and run it normally
but im not sure when i program the fobs, does the engine need to be running?
I dont have an owners manual so no luck there
Also do i need to hold the lock and un lock buttons down together to program the entry fob?
or is the passlock2 faulty
any thoughts on this would be much appreciated
many thanks
Marcus
Old May 11, 2012 | 06:22 PM
4x4blazerguy's Avatar
I'm not sure about a 99 from Europe, but my 98 I just finished programming two remotes for it.
get in car close the door
hold UNLOCK button on drivers door down.
turn on & off the ignition key twice not starting it.
release unlock button & lock should unlock & lock after you release the button.
then the car is in program mode.
then press the unlock/lock buttons at the same time on your remotes up to 30 sec until the car locks unlock themselves. Then do the same for other remotes
Hope this helps & works for you. Please let us know.
Old May 22, 2012 | 03:05 PM
redcruiser's Avatar
redcruiser is an unknown quantity at this point
Hi 4x4blazerguy
I have checked into this on numerous occasions, new remotes on European models can only be programed via a special scanner. I have only one working remote, if that dies I am in trouble as that seems to be the only way to deactivate the security system, to start the engine. Have another spare so if you find anyone who can program it please let me know. Where did you manage to get the five digit security code from as a matter of interest.
Adrian
Old Dec 6, 2012 | 07:29 AM
j.b-5742's Avatar
j.b-5742 is on a distinguished road
Originally Posted by redcruiser
Hi 4x4blazerguy
Adrian
Yeh where did you get your 5 digit code from.
Hi Men, Jim from Edinburgh here.
Old Oct 15, 2019 | 12:02 AM
AussieBlazer's Avatar
AussieBlazer is on a distinguished road
Cool Same Keyless entry issue
Hi Guys,
I'm having the same issue with my 2001 Blazer. I bought a new FOB on amazon that said it suited my model (is identical) the FOB will work from the outside but only if I put the FOB right up against the windshield towards what I assume is the sensor/RF receiver. The FOB also works when pressed beneath the steering wheel. I live in Australia and my Blazer is an imported Japanese RH drive model.
Old Nov 23, 2019 | 04:12 PM
Wdavie's Avatar
Wdavie is on a distinguished road
I’m thinking of buying a UK model Blazer but the remote fob is missing so I guess I’d have major problems getting the car running, may have a rethink.
Old Oct 24, 2020 | 02:12 AM
well it was easy to program a new remote and its still doing the same thing. I've found from reading some threads that it could be the receiving antenna/aerial thats usually in the center console. I haven't bothered to check yet! The RKE modual under the dash was easy to diagnose.
Droidster
Apr 26, 2013 03:04 PM
weazel
Sep 19, 2011 07:31 PM
gulljenta
Jun 28, 2011 08:26 PM
ABN31B
Jan 3, 2011 03:34 PM
ronaldo
May 16, 2008 04:39 AM
