Pulling 4 Different Codes, Could it be 1 item???
Old Aug 19, 2013 | 03:21 PM
RobMacLin's Avatar
RobMacLin is an unknown quantity at this point
Default Pulling 4 Different Codes, Could it be 1 item???
Ok, pulling 4 codes p0101, p0449, p0155, and p0135.
P0101, change maf sensor
P0449 change canister purge solenoid valve
P0155 + P0135 change both sensors
Changing these 4 parts should clear all 4 codes, but
could all 4 codes be pointing to a restricted cat???
Old Aug 19, 2013 | 03:47 PM
chris015's Avatar
Eh,not likely. Pick up a can of maf cleaner and spray down the inside of the maf. Mafs can cause some crazy problems.
DONT use carb,brake,throttle body cleaner.
Old Aug 19, 2013 | 03:58 PM
newguy's Avatar
I`ve seen one code cause other codes, but not a clogged cat doing this
Old Aug 19, 2013 | 08:55 PM
DTC's never tell you to replace a part, never. DTC's tell you what circuit the PCM detected a malfunction on. DTC's must be diagnosed and repaired one at a time, (starting with the first one), using the correct diagnostic flow chart. When the repair is complete, clear all codes and perform a General Motors Driving Cycle. If the check engine light comes back on before, during, or after the drive cycle is completed, retrieve the DTC's and repeat the process until the light stays off after the drive cycle is completed.
ant2297
Aug 6, 2010 06:10 PM
thereverendbill
Jun 19, 2010 10:12 PM
bigjoewebb
Jan 27, 2009 09:36 AM
mikeesho1
Oct 26, 2007 12:31 AM
drperry
Jul 4, 2007 04:25 AM
