Did I miss something? Everything I have read, on- and off-forum, says PAG 150 for an OEM compressor. Yet, they sent PAG 46 and the compressor says RL488 or equivalent, which is PAG 125 from what I could find on google. I'm pretty sure I need to use PAG 150 for this, but I would just like to double-check before proceeding.
https://cimg2.ibsrv.net/gimg/blazerf...0f1f6bb65.jpeg https://cimg3.ibsrv.net/gimg/blazerf...e73a23d9e.jpeg https://cimg4.ibsrv.net/gimg/blazerf...539654aa2.jpeg https://cimg5.ibsrv.net/gimg/blazerf...e49a0865a.jpeg https://cimg6.ibsrv.net/gimg/blazerf...0f3d507d3.jpeg https://cimg9.ibsrv.net/gimg/blazerf...314068e9f.jpeg |
This is the link to my write-up from when I installed my AC system. It might help. Apparently I had to use the PAG 46 oil for mine which was a one-for-one replacement for my original system.
https://blazerforum.com/forum/2nd-ge...ent-kit-97066/ |
I remember coming across this thread! I am actually planning on following some of the guidelines mentioned here in conjunction with other resources.
I am somewhat familiar with GPD, in that it is not OEM and uses PAG 46 by design. But since my part is OEM, I would think it should follow the fluid types/amount tables. |
2 Attachment(s)
Originally Posted by Taking_Notes
(Post 723134)
(Post 723138)
Here are the specs for my 99. Unfortunately they don't say what type of PAG oil to use. Perhaps a dealership parts counter could help you figure out which to use?
Ask the vendor, they may even exchange at no cost.
The oil type is dictated by the specific compressor make and model and is related to its design/clearances. That is why you can get two different after market compressor brands for the same vehicle that specifies two different oil viscocities. It’s a Denso vs Sanden ... thing, not a truck make and model or engine model thing.
George Compressor Model and Recommended PAG Oil:Bosch Axial.........................PAG 100Calsonic CR14.......................PAG 46 Calsonic CWV6.......................PAG 46 Calsonic DKV........................PAG 100 Calsonic V5.........................PAG 150 Calsonic V6.........................PAG 46 Chrysler A590.......................PAG 46 Chrysler C171.......................PAG 46 Chrysler RV2........................PAG 100 Denso 10P...........................PAG 46 Denso 10S...........................PAG 46 Denso 10SRE18.......................PAG ND-8 Denso 2C............................PAG 100 Denso 6C............................PAG 46 Denso 6CA...........................PAG 46 Denso 6E............................PAG 46 Denso 6P............................PAG 46 Denso 6SB...........................PAG 46 Denso 7SB...........................PAG 46 Denso SC08..........................PAG 46 Denso TV............................PAG 100 Ford FS10...........................PAG 46 Ford FS6............................PAG 46 Ford VF2............................PAG 46 GM A6...............................PAG 150 GM HR/HT............................PAG 150 GM R4...............................PAG 150 GM V5...............................PAG 150 GM V7...............................PAG 150 Hadsys HS-090L......................PAG 46 Hadsys RC17.........................PAG 46 Hitachi (all models)................PAG 46 Keihin (all models).................PAG 100 Matsu****a (all models).............PAG 46 Mitsubishi (all models).............PAG 46 Nihon DKV...........................PAG 100 Nihon NVR...........................PAG 100 Panasonic (all models)..............PAG 46 Sanden Electric.....................SE-10Y Sanden SD5..........................PAG 100 Sanden SD7 (key shaft)..............PAG 100 Sanden SD7 (splined shaft)..........PAG 46 Sanden SD7V.........................PAG 46 Sanden TR...........................PAG 46 Sanden TRF..........................PAG 46 Sanden TRS..........................PAG 46 Seiko-Seiki (all models)............PAG 100 Tecumseh (all models)...............PAG 100 Visteon RS-18.......................PAG VC-46 York (all models)...................PAG 100 Zexel DCV...........................PAG 100 Zexel DCW...........................PAG 46 Zexel DKP...........................PAG 100 Zexel DKS...........................PAG 46 Zexel DKV...........................PAG 100 Zexel TM............................PAG 46 George Here’s another oil viscocities chart. If you are wanting to confirm the proper oil viscocity your best bet is to communicate with Delphi for direction but you may well be right about pag 150. When I did my compressor about 100,000 miles ago I think I confirmed by matching up the compressor body with some reference outlines of different compressor models. George http://www.greenvald.co.il/wp-conten...ication-05.pdf |
George,
These lIsts should be a sticky! Where did you find the first list? |
Originally Posted by GeorgeLG
(Post 723176)
George After a quick search, it seems like my Delphi is a GM HT6, so PAG 150 it is. Any comments on all the links I just found during my search which brand the HT6 compressors as "known belly-leakers"? I was trying to keep everything OEM in an attempt to keep the replacement process as simple as possible, but now I am wondering if that O-ring is going to crap out early or if there is something that needs close attention to detail during the installation process to avoid this. (My bad if this should be a new thread.) |
(Post 723180)
George,
These lIsts should be a sticky! Where did you find the first list? Here you go Christine. This site also has a partial compressor identification section: https://www.aa1car.com/library/pagoil.htm George
(Post 723185)
Yeah, I just figured that since I purchased an OEM part, it wasn't important to make a distinction, but definitely noted for the future!
After a quick search, it seems like my Delphi is a GM HT6, so PAG 150 it is. Any comments on all the links I just found during my search which brand the HT6 compressors as "known belly-leakers"? I was trying to keep everything OEM in an attempt to keep the replacement process as simple as possible, but now I am wondering if that O-ring is going to crap out early or if there is something that needs close attention to detail during the installation process to avoid this. (My bad if this should be a new thread.) Some compressors come with a charge of oil already in the compressor, some come dry. Regardless, the process is to pour out the oil in any part that is removed and replace that amount of oil in the new part. If its a compressor and its pre-loaded with oil then you pour it out, and replace the proper amount. Alternatively there is a chart with the amount of oil that normally resides in each component (the oil is always distributed throughout the system). George |
| All times are GMT -5. The time now is 04:17 PM. |
