Push Button 4x4 Question?
Old Nov 11, 2008 | 09:32 PM
upblazer95's Avatar
upblazer95 is an unknown quantity at this point
Default Push Button 4x4 Question?
Hey was just curious, I had to replace the 4x4 Push button switch on the dash, but the 2WD-Hi light comes on like normal but when you push the 4x4 Low or High Buttons Nothing happens or lights up at all or anything. The other switch that I replaced was pretty busted up from the previous owner. I was wondering if there are seperate fuses for the 4-wheel drive system that need to be put back in or checked, and then when those push buttons are pushed they will do the flashing light thing and activate the 4 wheel drive.
Thanks,
Joe
Old Nov 11, 2008 | 09:39 PM
Default RE: Push Button 4x4 Question?
There is a fuse. I would check the connections at the TCCM to make sure that there is no corrosion.
Old Nov 11, 2008 | 09:45 PM
upblazer95's Avatar
Is that fuse under the hood? Or is it in the fuse panel that is inside the Blazer?
Joe
Old Nov 11, 2008 | 09:48 PM
Since you have not stated what you are driving, I have to assume that your screenname means something. For a 95, it will be the 4wd fuse in the fuse box inside on the driver side.
Old Nov 11, 2008 | 09:50 PM
upblazer95's Avatar
Lol ya i got a `95 Blazer LT
Joe
Old Nov 15, 2008 | 06:55 PM
upblazer95's Avatar
Its not the fuses, where is the TCCM at - Its snowing here and would really like to get the 4x4 working as soon as possible.
Thanks,
Joe
Chevy33
Mar 27, 2011 10:42 AM
91chevywt
Feb 21, 2011 07:12 PM
lakahahahman
Aug 7, 2010 11:39 AM
trapper_canada
16
Jan 1, 2010 11:04 AM
buggyblazer
14
Dec 23, 2008 08:22 PM
