Question about sensors
Old Feb 25, 2008 | 06:45 PM
user 1016's Avatar
user 1016 has a spectacular aura aboutuser 1016 has a spectacular aura about
Default Question about sensors
Quick question..Does the O2 Sensor regulate the idle speed and throttle control? or is there a seperate sensor for that? I know it measures the fuel/air ratio to the manifold..(I'm pretty sure anyways) Just wondering! Thanks!
Old Feb 25, 2008 | 07:21 PM
Default RE: Question about sensors
The idle speed is controlled by the Idle Air Control (IAC) valve. I am not sure what you mean by throttle control, but the cruise control is controlled by the cruise control module (follow the throttle cables - the one that doesn't go into the firewall is the cruise cable).
The O2 sensors monitor how much free oxygen is still in the exhaust which is a measure of how complete the combustion process was and the PCM corrects the air/fuel ratio accordingly to maintain complete combustion.
Old Feb 25, 2008 | 09:40 PM
user 1016's Avatar
Ok..so the question is what sensor would be off to make my truck surge rpms..and make it move forward? I figure it has to be a sensor some where..it's not the accelerator sticking..it seems to happen when the compressor kicks on...any ideas?
Old Feb 26, 2008 | 05:26 AM
drperry's Avatar
Could be your Throttle Position Sensor...
I know the computer bumps the idle up a few RPM when the compressor is on... So maybe your IAC is moving a little more than it should...
Old Feb 26, 2008 | 06:39 AM
I would remove the throttle body and clean it very well. I bet the IAC is sticking up a bit, causing it to over adjust when the PCM tells it to. The easiest way to clean the IAC is to remove the TB, but have a look at it, you may be able to do it with it still on the motor. The cruise cable can be a PITA to remove.
Old Feb 27, 2008 | 10:18 PM
user 1016's Avatar
cool! thanks guys...I was looking in a book and narrowed it down to that or the EGR...deffinately add it to the list of things to do to my blazer this spring...hopefully get my gas milage back up!
swartlkk
Apr 24, 2006 02:37 PM
Bgray
Engine & Internal
Jan 15, 2006 05:28 PM
LittleDan911
Dec 14, 2005 07:12 PM
mpp1970
Apr 7, 2005 06:22 PM
Blade69
Jan 20, 2005 01:12 AM
