quick question....
Old Jun 4, 2010 | 07:20 PM
sgg51688's Avatar
sgg51688 is on a distinguished road
Default quick question....
ok. i have a 98 blazer with a 4 inch lift and 31x10.5 tires. my situation is when im doing 55 behind another car, and we go uphill. to retain the 55mph, you obviously gotta give it some gas. but, my truck will got to 1800 rpm, (where it would usually be) then just drop to 1000 rpm. BUT, if i get on it and go to pass the other car, it has no lag at all and actually hauls some a$$.
question is... what is causing this lag??
i have a feeling it may be the ecu. i think a reprogrammed one would let the auto lock tourqe converter shift more effiecently...
or is this typical for the locking tourque converter?
can anyone please chime in on this???
Old Jun 4, 2010 | 07:35 PM
RonJon's Avatar
RonJon is an unknown quantity at this point
If you have a scanner that can view operating data I'd turn the key on (don't start it) and work the gas slowly and watch the throttle opening %. Make sure there's no "jumps" or "hangs". I'm guessing maybe the low end of the Throttle Position Sensor is getting flaky?
Old Jun 4, 2010 | 08:01 PM
sgg51688's Avatar
ok. thanks for the quick response. i have afew lating around. ill just change it and see what happens. ill post back when i do.
any other ideas? anyone?
Old Jun 4, 2010 | 11:43 PM
84BlazerS10's Avatar
What Ron said would be my guess. But I'm by no means an expert.
Old Jun 6, 2010 | 02:45 PM
sgg51688's Avatar
i did not have any, so im going to pick one up from local auto parts store on monday. i did however take it upon myself to change my belt, rear axle cover, and tranny mount... much better now. just need that sensor
Old Jun 6, 2010 | 05:32 PM
RonJon's Avatar
I hate to see anyone throw parts at a problem, wish you had the scanner to look at the info. Hopefully it works.
Old Jun 7, 2010 | 02:08 AM
Yeah, that is one nice thing about a new car but on a old car you can normally guess and get it right most of the time.
blazinwoody
Engine & Internal
Jan 11, 2007 05:30 PM
88s10Blazer
Nov 10, 2006 05:49 PM
88s10Blazer
Sep 26, 2006 10:19 AM
athleticdawg26
Jul 30, 2006 02:43 AM
black19
Jul 2, 2006 11:58 PM
