quick spark plug question wont take long.
Old Jul 7, 2010 | 09:03 PM
laidblazer's Avatar
laidblazer is on a distinguished road
Default quick spark plug question wont take long.
my 96 blazer with a 4.3 has one spark plug on the driver side that sits behind the steering stick. i changed all the rest just fine but cant figure out how to get that one out. anyone have any suggestions. thanks for your help.
Old Jul 7, 2010 | 09:32 PM
95Jimmy's Avatar
95Jimmy is on a distinguished road
I just did mine about an hour ago. The easiest way I've found to do it was to use a spark plug socket and a 3/4' wrench to turn it. I still need to pick up a set of wobble extensions- that would probably be the easiest way. Other ways as found on here..
https://blazerforum.com/forum/showth...spark+plug+gap
Make sure to check for the proper gap- one of mine was off out of the box- the rest were right. And DEFINATELY use AC Delco plugs!
Old Jul 7, 2010 | 10:15 PM
laidblazer's Avatar
i used bosch platinum plugs and thanks for the info
Old Jul 8, 2010 | 08:01 AM
midnightmekanik's Avatar
midnightmekanik is on a distinguished road
Just undo the steering shaft? I found that to be the easiest... One bolt on the end, and it just slides off the steering box. It's keyed too, so u really can't muck up reinstallation...
Old Jul 8, 2010 | 03:30 PM
adam10's Avatar
adam10 is on a distinguished road
the easiest way i found was a spak plug socket with the wobble built in to it.it makes it alot easier to put the new one in also.if you put a wobble on the end of your socket it makes it a little to long.
futuredoc
Oct 7, 2024 06:14 PM
4.3l trouble
Apr 7, 2019 06:54 PM
chris015
Aug 9, 2011 10:29 PM
bornla
Nov 28, 2009 11:55 AM
boulonman
Mar 5, 2007 05:10 AM
