Radiator flush 97 blazer
Old 12-09-2010 | 03:56 PM
Looee's Avatar
Looee is on a distinguished road
Default Radiator flush 97 blazer
I need to flush the radiator on my 97 blazer. I'm guessing there should be 1 or 2 plugs that need to be removed to drain the fluid but I can't see where they are. There is a metal plate right below the radiator that has the door to get to the oil filter. Do I need to remove that plate to get to the radiator drain plugs?
Old 12-09-2010 | 04:05 PM
The drain plug on the radiator is located just below the lower radiator hose on the passenger side of the radiator. It is a pain to get to and many people just pop off the lower hose.
Old 12-09-2010 | 04:10 PM
terry s's Avatar
terry s is on a distinguished road
If you wish to do a complete job and flush/drain the block there is a drain plug on both sides of the engine just above where the oil pan meets the block. They are usually pretty tight so a 6-point socket is a must. If you have 4wd the one on the driver's side is next to impossible to get to.
hroofblaze96
01-15-2020 05:39 PM
pfsantos
09-23-2010 04:58 PM
bigdaddykane93
01-04-2010 01:03 PM
portcqb
04-29-2008 10:56 AM
ZR 2
12-04-2007 04:53 AM
