rag joint change
Old Oct 20, 2012 | 03:45 PM
coolasice's Avatar
coolasice will become famous soon enough
Default rag joint change
anyone change their rag joint to get their steering wheel slightly off after? I changed mine today and after the steering wheel is turned slight turned to the right, like maybe 15-20 degrees or so when going straight.... any ideas? I know I put the shaft back on correctly.... maybe it was just that bad that it seemed straight but was just the play in the joint.
Old Oct 20, 2012 | 05:11 PM
chris015's Avatar
might end up being something else. these things seem to go through idler arms. jack it up. if the idler goes up and down when you try to turn the wheels change it.
Old Oct 20, 2012 | 06:59 PM
coolasice's Avatar
everything else is solid, rag joint was last on the list
Old Oct 20, 2012 | 07:43 PM
chris015's Avatar
Hmmm. Yea,other then maybe steering box,id say its the rag. Hows the control arm bushings lookin? Some people bypass that.
Check out "jeep steering shaft blazer 2nd gen" on google. You can swap out to a solid shaft. aka no more rag joint.
Old Oct 20, 2012 | 08:15 PM
xgiovannix12's Avatar
they have a universal joint kit for these trucks... Its better then the rag joint... They call them flaming river joints i think.
Summit racing has it and synergy off road
Old Oct 20, 2012 | 08:26 PM
chris015's Avatar
link john!?!?
If it fits a first gen,cool.
Old Oct 20, 2012 | 08:28 PM
Yes it fits 1st gens
Flaming River FR1746DD Billet Universal Joint S10 Blazer ZR2
They are pricy but worth it...I Plan on doing this someday
Edit: Ive seen cheaper.
Old Oct 21, 2012 | 07:19 AM
coolasice's Avatar
they'rs $72.99 on amazon with free ship... i don't have that cash to throw around, so i went with the rag replace instead. I didn't do anything else other then ball joints last year and just had it checked for alignment, all is well and steering slop is nearly all gone, so I'm gonna assume it was the worn rag joint that was causing the slop and when replaced it made the wheel crooked by a bit.
Old Oct 21, 2012 | 07:31 AM
newguy's Avatar
If the steering and alingment is fine maybe you coulg just pull the steering wheel and put it on straight
Old Oct 21, 2012 | 07:42 AM
coolasice's Avatar
i'd rather live with it crooked and have it straightned next time i need a alignment
