Random abs
Old 12-20-2011, 09:09 AM
chcknugget's Avatar
chcknugget is on a distinguished road
When I'm in neutral in 2wd I can spin the front driveshaft by hand. I don't feel any binding in 2wd and I know my 4wd works. The vacuum actuator is pulling the cable but I'm guessing the cable needs adjusting at the front differential.
Old 12-20-2011, 09:12 AM
If you can spin the front driveshaft by hand, you should be able to spin one front wheel with the other three on the ground. Being able to spin the front driveshaft with all 4 wheels on the ground confirms both 2HI in the transfer case and that the front axle is disengaged.
Old 12-20-2011, 11:51 AM
chcknugget's Avatar
OK I checked it again. I can rotate the tire by hand. But the axle is binding with the driveshaft a couple times each rotation. I can spin the driveshaft freely, but the wheel binds in spots and turns the driveshaft when I rotate the tire by hand. What does this mean?
Old 12-20-2011, 12:00 PM
Sounds like something is rubbing inside the front diff. The wheels should be able to spin without binding up or turning the front drive shaft provided the front axle engagement mechanism is fully disengaged. Does the same thing happen with the opposite front tire? If not, then the problem is likely in the front diff itself.
Old 12-20-2011, 01:09 PM
chcknugget's Avatar
hmmm... The same binding is happening on both sides. I guess the cable could be partially engaged. Or the shift fork mechanism is knackered. Everything seems to be fine when I'm traveling down the road- is this worth fixing?
Old 12-22-2011, 12:36 PM
chcknugget's Avatar
I had a shop look at it and everything is working fine. It was just the cv axles binding at that angle.
Tinted
03-15-2012 02:56 PM
xgiovannix12
06-28-2011 01:10 AM
iamchevyman5
02-28-2011 04:35 PM
stormshadow1
04-23-2009 09:46 AM
kkramer7
05-09-2006 07:44 PM
Quick Reply: Random abs
