Random Misfire
Old Sep 14, 2008 | 06:10 PM
bjsx8f's Avatar
bjsx8f is an unknown quantity at this point
Default Random Misfire
I had quite the problem with codes coming up as random misfires. I changed plugs, wires, rotor, cap, 02 sensors, map sensor, checked fuel pressure in the rail. After doing all this it still had a slight random misfire. I took the cap off that was only maybe a month old and noticed that on top of the rotor there is a little plastic elevated piece (tiny square piece) that catches the cap just a tad which causes the spark to jump around a bit. I bought new cap and rotor again to replace these and the new one had the elevated piece on it also. So I went ahead and cut it off and flush to the rotor and I have not had any other problems. No idea how i discovered this, just ran out of options so looked over the cap and rotor again and that was it!
Old Sep 14, 2008 | 07:46 PM
portcqb's Avatar
portcqb is an unknown quantity at this point
Default RE: Random Misfire
Were these both delco cap and rotors, if not thay may have been the problem. The cheaper ones seem like a good idea when you are looking at your wallet, but they often use inferior metals in their contacts.
Old Sep 14, 2008 | 08:05 PM
bjsx8f's Avatar
yeah they were duralast cap and rotors from autozone.
Old Sep 16, 2008 | 08:19 AM
cowboy's Avatar
cowboy is an unknown quantity at this point
i have a 95 blazer 4.3, it had missfire on cylinder 4 at first so of course i changed the plugs and wires cap and rotor. than it still did it so i cleared the codes drove it and now it says multible missfire.. any ideas?
thanks james
Old Sep 17, 2008 | 07:08 PM
1badblaze's Avatar
1badblaze is an unknown quantity at this point
after replacing ev erything on my blazer i found my p0300 was sticking valves on cyl 2 and 4 i caught it with a vacumn gauge and multiple compresion readings. i waitecd till the missing started and then did a compression test pulled the head sent it to machine shop and it runs like new again
Old Nov 28, 2008 | 08:48 AM
rmv42158's Avatar
rmv42158 is an unknown quantity at this point
1badblaze:::: did you have to do anythign special when reinstling the head after the shop went though it? I have a missfire on #5 and i think it's the valve since it's tapping like crazy (still have to do a compression check).I want to do myself since it's a second car but was curios about reinstalling the head.
BlaziNator
54
May 25, 2010 05:15 PM
1996BZR
19
Dec 23, 2008 03:07 PM
SlimshagE
Apr 9, 2007 10:00 PM
jdblazer
Dec 20, 2006 12:58 PM
jdblazer
Dec 17, 2006 03:37 PM
