Random stalls and no starts
Okay, I've got a 2001 Jimmy, that will be driving fine one minute and the next it stalls out while driving, or it will be driving fine all day then the next morning won't start.
ICM -- replaced 7 months ago Fuel pump -- replaced two months ago Fuel filter -- replaced two months ago IAC -- replaced last week Alternator -- checked, good Battery -- checked, good Any ideas would be greatly appreciated. |
Any codes?
It's just running fine, then shuts off, or it runs real rough, and eventually stalls? I know you said you changed the fuel pump. Was there a fuel pressure issue? Possibly a problem with the injector/regulator |
...as for the pump. we recently had a topic "why is my truck eating fuel pumps", where OP has been replacing fuel pumps over again every two months or so. I wouldn't trust records, but do the tests. Scanner may give You some of idea what happens, if You look up the fuel trims.
Originally Posted by cleburne red
(Post 708999)
Any codes?
It's just running fine, then shuts off, or it runs real rough, and eventually stalls? I know you said you changed the fuel pump. Was there a fuel pressure issue? Possibly a problem with the injector/regulator Fuel pressure is good, 58 PSI, leak down test is good too. My truck doesn't seem to eat fuel pumps, it does like the taste of ICMs though, so I wouldn't put that out of the running for cause either. |
Originally Posted by Mike.308
(Post 709004)
I know that thread all too well... Lol Knock on wood, but I think I might have gotten on the good side of the fuel pump gods. New ac Delco pump, replaced the filter and the lines from the filter back, rebuilt the electrical connector (I've got a buddy with the tools to do weatherpacks) and washed out the tank. Seems to be holding |
@cleburne red
LOL I didn't remember it was You. I'm glad You didn't scrap Your ride, cause You wouldn't be here on BF :) As for the topic, if it runs fine and never rough, that would rule out the spider. Fuel test rules out the fuel pump. Except, the problem is intermittent, so best would be to check the fuel pump i.e. when the ride was settled over a night and doesn't want to start. As for the ignition - the very basic test is to check for 1" strong spark. Intermittent problems are generally PITA, so the main problem is to perform the tests, when it exists. |
(Post 709046)
@cleburne red
LOL I didn't remember it was You. I'm glad You didn't scrap Your ride, cause You wouldn't be here on BF :) |
This is getting aggravating.
The random stalls and no starts continues. Trying to track it down I checked the fuel pressure and done a leak down test, so not the fuel; has to be ignition or electronic ...something. I've now replaced: IAC ICM Ignition switch and lock cylinder It's not throwing any codes, ran great for a few days and now this morning.....no start. If I had any hair left I'd being pulling it out. SOMEONE PLEASE HELP!!!!! |
When it's not starting, you getting any spark?
(Post 709676)
Don't know if this might be as simple as this, when it did no start this morning I was just checking connections and trying to start it up, after I "pushed in" the connectors for the coil and ICM it started right up. did some research and found the pigtails (standard motor S551 & S656) ordered them from amazon and will be here tomorrow, so I'll splice them in and see if it really could be that simple. |
