Random warning lights
Old Aug 24, 2010 | 08:54 PM
Tortex53's Avatar
Tortex53 is on a distinguished road
Default Random warning lights
Hi, I have a 1995 Blazer 2dr. I've only had it a couple of days, but the ABS light and brake light seem to be coming on randomly. I was at a stop light and the ABS light came on for a couple of minutes and then went off. When I arrived home, the ABS light and then the Brake light came on for about twenty seconds and then they went off. One thing that I noticed is that I had just turned on the a/c when the ABS light came on the first time, and the second time (ABS and Brake light) they came on right when I rolled down the driver's side window. Thanks for your help!
Last edited by rriddle3; Aug 25, 2010 at 06:49 AM. Reason: MOVED POSTS TO ORIGINAL THREAD
Old Aug 25, 2010 | 06:00 PM
Its possible that you could have a bad ground or something. The ABS system may have stored a fault code.
Old Aug 25, 2010 | 09:35 PM
cbr995's Avatar
Haha! This helped me, too.
I was about to do a search, and saw this. 'Cept mine just does it randomly after startup. Not always when I'm moving, though...
Old Aug 26, 2010 | 10:55 AM
Tortex53's Avatar
I don't know if this has anything to do with the problem, but last night after changing my fuel pump I started up the car. I shut it off and then a couple of minutes later it made a clunking noise and the electrical completely died: no dome light, warning lights, clicks or anything. After about an hour I tried again and the dome light and warning lights came on, but when I tried to turn over the engine everything went black again. I checked the voltage at the battery and it showed 12.7 volts. Could this be related in any way?
bigtone23
Dec 10, 2012 03:17 AM
Bad Bear
Dec 30, 2010 11:25 AM
Zane25-hitch
Jan 17, 2010 12:07 AM
old 5k0ol
Jun 23, 2009 06:23 PM
davidshaw291
Oct 11, 2007 08:03 AM
