re: P0410
Old Aug 21, 2008 | 08:31 PM
ZR 2's Avatar
ZR 2 is an unknown quantity at this point
Default re: P0410
Hi there, I read the what the code explanation is in the DIY section but does anyone have any step by step instructions how to replace the air pump, hose & air check valve....how diffilcult is it to replace the relay if that is the part thats broken? Gonna check to see if the fuse has popped tomorrow and the relay this weekend...any info. will be appreciated
2001 ZR2 Blazer
thanks
Old Aug 22, 2008 | 08:27 AM
Default RE: re: P0410
As far as replacing the relay, just pull it out and push the new one in.
The pump is located under the radiator. If you take a look at it, it is fairly straight forward as far as removal. The intake tube should be clamped to the side of the fan shroud on the passenger side about half way up. I have posted pictures of how it looks in at least one other thread.
AKYooper
Dec 27, 2013 01:51 PM
steve
Nov 4, 2008 07:02 PM
steveinmd
Jan 9, 2008 10:03 PM
BlazinJay84
Dec 13, 2007 09:38 PM
flyinbrad
Engine & Internal
Jan 8, 2007 11:40 AM
