Re' vacuum line
Old Mar 27, 2011 | 06:29 AM
kennybopaloo's Avatar
kennybopaloo is on a distinguished road
Default Re' vacuum line
under the hood on the drivers side is a vacuum line that goes thru the fender wall.
you cant follow it because it disappears. mine is dryed out and needs replacing.
everything on the vehicle operates OK, but we like to replace worn out itmes before they give us trouble......
Old Mar 28, 2011 | 02:33 PM
Hank's Avatar
Hank is on a distinguished road
Smile
Just twist and pull gentle , be careful not to break plastic fittings!!
Install new!
Ready!!!
Greetz Henk.
Old Mar 29, 2011 | 04:43 AM
Default RE; Vacuum
we dont under stand.
the vacuum line goes somewhere thru the fenderwall and disappears.
we can't follow it thru the firewall to pull it or twist it.
thanks,
Old Mar 29, 2011 | 07:19 AM
vegie_2's Avatar
vegie_2 is on a distinguished road
There is a vacuum tank in the fender you can see it with a mirror, once you pull it off you will only feel a small nib where it attaches.
Make sure you change out the hose all the way down to the electric smog pump under the radiator mine was mush.
Old Mar 29, 2011 | 07:54 AM
Default RE; Vacuum
thank you ....................................
Old Mar 29, 2011 | 12:01 PM
Cobra 2-6's Avatar
Cobra 2-6 is on a distinguished road
I'm getting weak vacuum on mine now too- having trouble with the 4wd and everything. I'm planning on redoing all the vacuum lines. Were there any check valves that needed to be replaced?
Old Mar 30, 2011 | 10:24 AM
Hank's Avatar
Isn't here somewhere on our beautiful FORUM, a vacuum-line schedule or so.
So that we can check our lines properly? and we don't forget to replace an inch or so?
Greets, Hank.
Old Mar 30, 2011 | 12:24 PM
Default RE; Vacuum
well i finally found the vacuum line that goes thru the fender wall. it is a little tit that you pull off the hose and replace.
someone mentioned there is a vacuum line that goes to the smog pump.
where does the vacuum line come from and exactly how do you find it by the radiator.
i was under the radiator today and did not see any lines over there.
Old Apr 1, 2011 | 07:48 PM
4good's Avatar
4good is on a distinguished road
its electric on the right side mounted to the cross member has what looks like heater hose going to it
Old Apr 2, 2011 | 05:44 AM
Default re. vacuum
on the drivers side or the passengers side.............
