rear bearing race on 98 blazer
I have a 98 blazer 4wd. Does anyone know if the bearing has an outer race or does it just ride on the axle tube? I was using a slide hammer to remove it and only got the rollers out. Any help would be appreciated. Thanks
The outer axle bearing is assembled with the rollers inside the outer race, so it all comes as one item. If you only got the rollers the rest is still in the housing and you need to remove it.
Look at a new one and you will see what I mean.
