rear brake swap ?
Old Apr 27, 2007 | 05:00 PM
eelding's Avatar
eelding is an unknown quantity at this point
Default rear brake swap ?
can or will rear disc brake set upfrom a 99 blazer bolt on a 93 blazer rear end
Old Apr 27, 2007 | 05:07 PM
20Blazer00's Avatar
Default RE: rear brake swap ?
It might but measure backing plate mounting bolt area to make sure it is the same. Or you could do the easier way just swap rear ends and master cylinder from the 99...
Old Apr 27, 2007 | 05:55 PM
eelding's Avatar
i am driving the 99 cant find a rear end so i am trying to make something work
Old May 2, 2007 | 12:54 AM
RCars2's Avatar
RCars2 is an unknown quantity at this point
Why dont you use the the drum system thats already on the 93 rear end? It should work just fine. Granted its not the same as having discs but if its gotta work that should get ya good. Might have to adapt a line or two but you should be golden otherwise.
chevyblazer
May 22, 2014 03:15 AM
step66
Jan 12, 2013 10:51 AM
bill737
Jun 24, 2011 04:24 PM
hcii
Nov 3, 2010 08:30 AM
reagor
Apr 4, 2010 02:48 PM
