Rear Bumper
Rear Bumper
I ****ed up my rear bumper. From what I understand there are 3 parts to the rear bumper? The main bumper where the rear hatch is, then the two side pieces and two bumper fillers? I have to replace the main bumper that fits across and possible the side rear. How doI start?
RE: Rear Bumper
It helps us to know what year your vehicle is. This is for a 2000 Blazer
First remove the bumper extensions
[ol]Remove three screws securing the rear bumper extension to the wheelhouse panel.
Remove the bolt that retains the rear bumper extension to the brace.
Remove the nuts that retain the rear bumper extension to the rear quarter panel[/ol]
Remove the license lamps
[ol]Remove all of the step pads from the bumper.
Remove the clips securing the fascia at the bottom of the impact bar.
Remove the fascia. [/ol]
[IMG]local://upfiles/2910/101230C8B49F472A8FA1B6A21BEF3C2A.gif[/IMG]
[IMG]local://upfiles/2910/BA625A2395D24FBDB10686FD7D06AF78.gif[/IMG]
RE: Rear Bumper
Well i recently had to remove my center rear bumper fascia. All I needed to do was to pull up the top rubber step pad and remove the bolts from the bumper mounting brackets that are accesible when the rubber step pad is removed, the bottom step pad does not need to be removed to remove the fascia. It is not necessary to remove the side "pods" unless you are replacing one from damage.
Since you need to remove the rear bumper fascia to replace it then you will need to remove all the other parts, license plate lites w/harness and the lower step pad. These items can be removed after fascia is taken off the bumper mounting brackets...
RE: Rear Bumper
I have a 97' jimmy. I need to replace the center rear bumper from hitting something.
RE: Rear Bumper
ORIGINAL: anguyen
I had removed mine to install a trailer hitch and the instructions for the hitch installation recomended removing the center section and that is how it went....
kids blaze
05-05-2006 04:48 PM
