Rear Caliper Bleeder Location
Old Jan 20, 2014 | 12:26 PM
metalmeltr's Avatar
metalmeltr is on a distinguished road
Default Rear Caliper Bleeder Location
2001 Blazer 4x4
what is the proper location of the rear brake caliper bleeder screws? Top or bottom? Mine are on the bottom, I have always understood that these should be on the top because air will rose through the fluid. Are my calipers on the wrong sides? I have never had them completely removed so i haven't mixed them up.
Old Jan 20, 2014 | 04:55 PM
Diaita's Avatar
Bleeder has to be at the top. You're right, they were installed on the wrong sides.
Old Jan 20, 2014 | 05:32 PM
metalmeltr's Avatar
Ok thanks, guess I have to take it apart for a third time.
Old Jan 22, 2014 | 07:27 AM
Pewter2002's Avatar
Pewter2002 is on a distinguished road
Curious, on my 2002 2 wheel drive, the driver side rear bleeder is on top, the passenger side rear is on the bottom.
Old Jan 23, 2014 | 01:35 PM
metalmeltr's Avatar
That means that the caliper on the passenger side must be designed for the drivers side, it must have been replaced at some point with the wrong caliper.
Old Jan 24, 2014 | 07:59 AM
Pewter2002's Avatar
Even more curious. I bought the Blazer new and recently got rear replacement loaded calipers from NAPA. No one else has worked on the brakes. The OEM set up was the same with the orientation of the bleeders. Maybe they built it on a Friday evening.
Old Jan 24, 2014 | 11:13 AM
Diaita's Avatar
According to NAPA, they have the same part number for left and right, BUT anso show two different part numbers for left and right that have bleeders on different sides
NAPA Calipers
Old Jan 25, 2014 | 04:44 AM
Pewter2002's Avatar
I see now. Thank you. I didn't go the extra step with the part numbers. Since they both bolted up I overlooked that. I did leave the RR loose with the bleeder pointed up while it gravity bled. Learn something new everyday. Thanks again for pointing this out.
pbd3mon
Oct 23, 2011 01:45 PM
bugsbunny16374
Jul 27, 2010 11:10 PM
jimminiquick
Aug 3, 2009 12:35 PM
chevyman30571
Feb 18, 2008 10:35 PM
