can't find clutch bleeder screw on 2000 blazer
Old Feb 18, 2008 | 08:54 PM
chevyman30571's Avatar
chevyman30571 is an unknown quantity at this point
Default can't find clutch bleeder screw on 2000 blazer
I need to bleed my clutch on my 2000 blazer. I can't find the bleeder screw. Also near the clutch fluid resivoir there is a vacuum line that is just hanging there and there is no plug in the end of it and all i hear is a loud hissing. Does the vacuum line go anywhere or is it supposed to have a plug in it??
Old Feb 18, 2008 | 09:56 PM
Default RE: can't find clutch bleeder screw on 2000 blazer
The bleeder should be located on the driver's side of the bellhousing near where the bellhousing meets the front of the transmission case.
About the vacuum line... It should be plugged into something. It may be the line that supplies the HVAC system. Is the HVAC system working properly? Could you possibly take a picture of where this line is and what it looks like?
Old Feb 18, 2008 | 10:19 PM
pm sent.
Old Feb 18, 2008 | 10:20 PM
could it possibly be that the piece of vaccum line was plugged and the plug fell out??
Old Feb 18, 2008 | 10:35 PM
Don't think so. If nothing else seems to be affected, then it may be that it was just plugged, but again, I doubt it...
Also please try to keep everything in the open forums. If for nothing else than to benefit others that may be experiencing the same problem. But I am far from the most knowledgable person here. I often cannot respond for long lengths of time due to work and keeping problems in the open forums allows everyone that has the information you require to comment.
Thanks,
bigdaddykane93
33
Dec 9, 2012 02:31 PM
pbd3mon
Oct 23, 2011 01:45 PM
bugsbunny16374
Jul 27, 2010 11:10 PM
jimminiquick
Aug 3, 2009 12:35 PM
