Rear Differential, Fuel Lines
Old May 3, 2008 | 04:06 PM
Default RE: Rear Differential, Fuel Lines
Possible, but I doubt it...
Old May 3, 2008 | 05:20 PM
tkf5651's Avatar
tkf5651 is an unknown quantity at this point
I found a guy on craigslist who has the gasket and cover brand new for $22. I am going to pick that up monday and install, we will see how it goes.
Old May 3, 2008 | 05:30 PM
TripleBlackBlazer's Avatar
ORIGINAL: tkf5651
Um, is it chrome? A regular replacement at Advance Auto is like $13, and I want to say the gasket comes with it. But if not the gasket is only $4.
If it's chrome or fancy-schmancy then I could see the $22. I just bought the regular one and hammer-painted the outside to prevent rust.
Old May 3, 2008 | 06:12 PM
tkf5651's Avatar
It's OEM, advance auto doesn't have the cover in, and would take 5 days to order.
Old May 3, 2008 | 07:20 PM
$22 sounds about right for OEM parts.
Old May 4, 2008 | 11:11 AM
drperry's Avatar
The only time I saw an 8.5" on a 4 door was a fleet special order...
Specifically, RCMP issue
That definitely does appear to be a 7 5/8"
Since it doesn't look like mine
Old May 6, 2008 | 06:55 PM
tkf5651's Avatar
So far hardest part is getting all the bolts out, some are crumpling up when you even touch them
Old May 12, 2008 | 08:47 PM
tkf5651's Avatar
as you can see, I twisted the head right off of one of the bolts, I put it back together anyways, and I dont think that it is possible to get that bolt out without drilling it and tapping it so I will probably leave as is, and keep an eye on it, it isnt leaking right now so im going to let it live for a minute.
Old May 12, 2008 | 08:58 PM
I would definitely get that out of there. It should be easy to drill and extract. Just center punch what is there first to make sure that you start centered. You'll also want to bolt down the brackets again...
Old May 12, 2008 | 09:06 PM
portcqb's Avatar
portcqb is an unknown quantity at this point
Gears look almostnew after you cleaned them up. Im doing this tuesday hopefully my bolts will come out they look prettttty rusty.
