rear end problem
Old Apr 11, 2010 | 05:49 PM
blazer03slam's Avatar
blazer03slam is on a distinguished road
Default rear end problem
have a 03 blazer 2wd clunks in the rear end only when you put it in reverse and only does it sometimes?
Old Apr 11, 2010 | 07:45 PM
bandidolenny's Avatar
Put the parking brake on and the tranny in neutral (engine off of course)...
Crawl under there and grab ahold of the drive shaft. Rotate it back and forth as well as up / down and sideways. Check the U-joints and check for play in the rear-end pinion.
Old Apr 11, 2010 | 08:00 PM
Luvthyblazer's Avatar
Luvthyblazer is on a distinguished road
Probably a U-joint
Tranny may be on its way out.
Rear end take the cover off and inspect gears look at them closely.
Blazers are hard on spider gears.
I had mine blow the pinion gear it shatter in pieces, my spider still looked good imagine that.
Old Apr 11, 2010 | 08:22 PM
1998MSO's Avatar
1998MSO is on a distinguished road
You didn't mention how many miles are on it, but I would check the U-joints first.
doktornasty
Nov 3, 2013 03:12 AM
chriskifer86
Jun 13, 2013 08:47 PM
brino1
Feb 25, 2011 08:05 PM
99blazerguy
Nov 10, 2010 04:28 PM
dart08
Sep 24, 2009 04:56 PM
