Rear Hatch Problem
Old Mar 4, 2007 | 09:24 AM
blazerdave2001's Avatar
blazerdave2001 is an unknown quantity at this point
Default Rear Hatch Problem
I have a 2001 2dr blazerand the rear glass will not unlatch. I have taken the panel off and found that the plastic piece that usually breaks on the motor is OK. I did find that there is no power getting back there from any of the switches or remote. Fuse is ok. I believe it is the BCM. Does anyone have any experience with this problem? Any schematics would be nice. I have the Haynes wiring manuals and they are useless......Thanks
Old Mar 4, 2007 | 11:15 AM
drperry's Avatar
Default RE: Rear Hatch Problem
Is the motor itself still good?
Try unplugging it, and test the voltage while someone hits the button, and maybe double check to see if the plug on the back of the button panel is still attatched...
Does the hatch open with the key?
Old Mar 4, 2007 | 01:28 PM
Kordog's Avatar
Kordog is an unknown quantity at this point
Here are some wiring diagrams for you, Korey
[IMG]local://upfiles/4089/640052F4AF684A1C97424B337840C342.gif[/IMG]
[IMG]local://upfiles/4089/321CABE2F4D64B2696F3659820C85EE7.gif[/IMG]
Old Mar 4, 2007 | 09:44 PM
Thanks for the diagrams Korey, found a problem with window release relay in the engine fuse box. That diagram saved me a lot of time...Thanks again for everyones help..Dave
Old Mar 4, 2007 | 09:56 PM
Kordog's Avatar
No problem, that is what we are here for!!!
Old Mar 5, 2007 | 12:13 AM
FFJustin99Chevy's Avatar
FFJustin99Chevy is an unknown quantity at this point
I've had the same problem. There actually wasn't anything wrong with the rear hatch. It was a problem with the power mirrors. If you look in the fuse box under the hood, you'll notice that the power mirrors and the pop for the rear glass are on the same relay. When it would rain, rain would short out the power mirrors which would in turn cause the rear glass to malfunction. Try taking out this relay and putting it back it which will reset it. Also replace the fuse for this relay if it burned out. You'll prob notice that it comes back to life.
Old Mar 7, 2007 | 04:14 PM
bgillette78's Avatar
bgillette78 is an unknown quantity at this point
i had the same problem and i went to the dealership and asked about it. there is a fuse that blows for the power mirrors and the locks and this includes the hatch. it is under the hood a 2 amp fuse that blows and they said it could be replaced by a 5 amp and not harm the circuit works fine now. that is the first and only time i will probably get something free from the dealership
tmar89
Apr 23, 2013 10:23 AM
Wexinlo
Jun 8, 2012 02:46 PM
1baggedblaze
Apr 13, 2010 04:52 PM
magnum434
Dec 3, 2008 10:06 AM
Blasir
Aug 17, 2008 07:46 AM
