Rear Split Hatch won't open????
Old Nov 6, 2012 | 10:29 AM
4x4blazerguy's Avatar
Question Rear Split Hatch won't open????
I did a search on this & if I read things correctly the only way to get the window open to make a repair is to break the inner panel. Is that correct? I have my 98 Blazer 4dr with a split rear hatch. The window opens with the button then you reach inside to lower the gate part. I can hear the actuator working when you push the button, use the button on the dash or key, but the window won't open.
Old Nov 6, 2012 | 12:08 PM
1sttimejimmyowner's Avatar
1sttimejimmyowner is on a distinguished road
Default Please let me know what you find out
Because I have the same problem with my 96.Thankx
Old Nov 6, 2012 | 10:22 PM
Diaita's Avatar
What if you pulled the tailgate hinge pins out and unbolted the helper spring? Could you then lift the glass and door assembly out enough to remove the screws for the inner panel? I haven't tried it, but maybe...
Wexinlo
Jun 8, 2012 02:46 PM
bodnar720
Mar 24, 2012 07:04 PM
Blake726
Sep 11, 2011 05:56 PM
Major Tom
May 23, 2011 12:34 PM
Kellen
Sep 21, 2006 12:44 PM
