Rear Sprayer
Old Mar 5, 2017 | 08:04 PM
LuckyAce's Avatar
LuckyAce is on a distinguished road
Default Rear Sprayer
Didn't even know my blazer had this thing until today when a friend showed me the button on the switch. Tried to use it and I hear a very loud sound from the engine area on the driver's side, but nothing sprayed out of the wiper. I tried the front sprayer and it sprayed so unless they are separate reservoirs I have no idea where to look.
Old Mar 5, 2017 | 08:55 PM
Stumpalump's Avatar
Stumpalump is on a distinguished road
One Resivior with two pumps. The upper is for the rear. Mine was clogged at the little hose coming out of the tailgate.
Old Mar 7, 2017 | 11:04 AM
Bagherra's Avatar
Bagherra is on a distinguished road
Yeah..also if the reservior is low, the rear sprayer will stop before the front.
Old Mar 7, 2017 | 03:53 PM
LuckyAce's Avatar
The fluid level was pretty much gone, which would explain why nothing came out at all. Sadly after refilling it I can see washer fluid dripping out of the tail gate. Looks like this may be too much work for what it is worth.
Old Mar 10, 2017 | 09:42 AM
Bagherra's Avatar
Not that hard to do...same thing happened to me..
Old Mar 11, 2017 | 06:03 AM
newguy's Avatar
Its the upper upper pump on the tank. there`s a one way valve in it, 5 minutes. How can that be to hard? Who pumps gas for you?
Old Mar 11, 2017 | 11:58 AM
LuckyAce's Avatar
It's leaking out of the tailgate, doesn't that mean I need to rip off the plastic panel? I took the door panel off last summer to replace the mirror and ended up breaking the push pins, now the panel rattles on rough roads. One panel doing this is annoying enough. Not to mention if it is the line that is leaking somewhere replace it, the line that runs the entire length of the car?
Old Mar 11, 2017 | 12:16 PM
newguy's Avatar
One way valve is in the pump in the tank in front. Thats all. If the valve is bad, it will leak in the rear,but if its leaking out the gate, thats up to you
Old Mar 11, 2017 | 12:40 PM
LuckyAce's Avatar
When I tried to use the sprayer there was a nice blue stream that came from the bottom of the lift gate, so it could be the valve instead of a leak? How does the valve in the engine compartment cause a leak all the way in the lift gate? Do you by chance have a part number for the valve?
Old Mar 11, 2017 | 02:45 PM
newguy's Avatar
Sorry I misread the post, it does sound like rear panel removal is needed
